911 Forum 1964-1989
2nd real dumb question of 2012.
Old 02-09-2012, 04:48 PM
911 Crazy
SPAM addict
911 Crazy's Avatar
Location: Acadia National Park, Northeast Harbor, Maine
Question 2nd real dumb question of 2012.
So I put new tires and spacers on my car and have quite a bit of shimmy and shimmer at 60mph and above. Have not had an alignment done but figure since the seller had 45's and not 55's on the front as it is now, that could also explain the problem. Also should an alignment be done through a P-Car shop or can most tire stores perform adequately? Thoughts? Thanks.
Old 02-09-2012, 05:34 PM
ron mcatee
ron mcatee's Avatar
Tim, the only place I would take it is to a reputable Porsche shop. Other shops say they can align Porsches, but in my 44 years of Porsche ownership, I've only found one. Do you have a local Porsche shop. Sounds to me like you need a 4 wheel alignment and front end checkout. Also, check into corner balancing. You need to recheck the tires to ensure they are mounted and balanced correctly. There's a lot of variables, but a good reputable Porsche shop should be able to tell you where the problem lies/lays.
Old 02-09-2012, 05:53 PM
911 Crazy
SPAM addict
911 Crazy's Avatar
Got to remember that this is Maine. Closest P Shop is 100 miles away, but will call them tomorrow. Thanks.
Old 02-09-2012, 06:28 PM
rusnak
I haddah Google dat
rusnak's Avatar
A frame alignment shop can usually do it also, but you must be very selective about which shop performs this procedure.
Old 02-09-2012, 06:48 PM
911 Crazy
SPAM addict
911 Crazy's Avatar
Will it hurt the car to drive it the 100 miles to the shop or should I have it flatbeded?
Old 02-09-2012, 07:31 PM
rusnak
I haddah Google dat
rusnak's Avatar
pfft....100 miles is not a problem. You should see my wacked out alignment. Just kidding! If it's tracking well, then you might be ok. My concern would be for the brand new tires!!! OTOH, flatbedding a 100 miles is not cheap either.....
Old 02-09-2012, 07:45 PM
rusnak
I haddah Google dat
rusnak's Avatar
If the spacers are too thick, then the wheel has no way to "register" into the hub. The wheels are hub-centric.
Old 02-09-2012, 11:02 PM
911 Crazy
SPAM addict
911 Crazy's Avatar
Car tracks well. Hub centric, what is that? I put 3/4 inch spacers on the front and 1.25 inch on the rear. Looks real cool though!
Old 02-09-2012, 11:19 PM
Peter Zimmermann
Peter Zimmermann's Avatar
Tim, when you say "spacers," do you mean spacers between the hubs and wheels? If yes, who did the longer lug nut studs? And are you sure that the studs were put in correctly? And why did you do this? And why isn't the car going back to the tire/wheel installer for a proper balance?
Old 02-09-2012, 11:39 PM
mclmk8d
mclmk8d's Avatar
Tim, if you are coming down here, Kevin recommended a shop near his shop called AMF. They do high-speed balancing and fixed the shimmy I had at 60+ mph. Let me know if you need their number
Old 02-09-2012, 11:58 PM
User 4221
User 4221's Avatar
You are in a cold climate where the car sat for a week-ish, right. I would bet money you have a flat spot that will disappear once the tires warm up.
My Targa develops flat spots and a shimmy at 80 then disappears when warm. Also, certain stretches of road make it more pronounced.
Old 02-10-2012, 12:41 AM
911 Crazy
SPAM addict
911 Crazy's Avatar
The spacers had their own studs which the tires mounted to. Why, I liked the more aggressive look without lowering. I had the tires mounted + balanced and I installed them. Might be because the car did sit for 2 weeks. I put summer performance tires on. Could that cause it even though it was 40 today but the car is stored in a 60+ degree garage?
Coming down with the minivan, joy! Wife and kids are flying down. I get 4-5 days of peace and quiet!!! My wife will drive it home and I'll follow her in your, oh I mean my new car!!! What city are you in?
Only drove it about 15 miles today but it was in a 60 degree garage. Could be flat spots?
Old 02-10-2012, 08:38 AM
Jay Gratton
Jay Gratton's Avatar
Tim,
What is the close shop in Maine you are referrring to up there? I can make some suggestions or at least put you in contact with Ray Ayer in Gardner (sp) that can point you in a direction. Ray knows EVERYONE in Maine when it comes to high end sports cars (esp. Porsche).
Old 02-10-2012, 08:59 AM
911 Crazy
SPAM addict
911 Crazy's Avatar
Originally Posted by Jay Gratton
Tim,
I was referring to the P shop in Gardner. Is that Ray?
Old 02-10-2012, 09:01 AM
Jay Gratton
I would assume so. If it is Ray Ayer's place he is very good!
Quick Reply: 2nd real dumb question of 2012.
