2nd real dumb question of 2012.
#31
Just for thoughts, I may add that ABS brakes do not work right with a positive scrub radius. This was a major design objective behind the late offset 944 suspension and the 964.
On another note, I may suggest Tim; pick up a copy of "How To Make Your Car Handle" by Fred Puhn. It is an easy read that explains fundamental chassis dynamics well without being totally scientific and boring. Things like roll radius, polar moment of inertia, wheel offset, and basic alignment primary angles are easily explained and you will never look at an automobile the same. This and a good weekend at a PCA drivers Education will shine a new light on your Porsche and car enthusiasm.
#32
I haddah Google dat
You might consider Turbo Twists. You'd have more backspacing, so you'd actually need the spacers, plus you'd be able to put 265 17" tires back there. They might not look totally correct, and probably would need a tail to balance them out, but they'd be very very wide.
#33
SPAM addict
Another thought. When I installed the spacers, the rears went on easily but the fronts would not go all the way on. I did finally get them on when screwing on the lugs. Figured it was just a tight fit. But did I f**k up the wheel hubs???
#34
I'm not sure what the problem on the front could be, but the spacers may not fit over the grease cap on the center of the hub. Just a hunch. I wouldn't go so far as to say you F'ed up anything, but you will find out what it is when you take them off. let us know.
#35
SPAM addict
#36
Sh**can the spacers and see how it behaves. These spacers are going to cause you big problems, and I mean BIG.
This will give you an idea:http://en.wikipedia.org/wiki/Scrub_radius
Other problems are on the way if you continue with the spacers and don't compensate with different wheels. Sorry if this is bad news.
If you want "aggressive looks", do it with different wheels/tires.
#37
Then you could apply for ugly 911 OTY award, as well, IMO.
#38
SPAM addict
Bingo. That's where I was going with my earlier post, then forgot to follow up. Tim, when I had my shop we would not install those spacers for a customer, and wrote a warning on every repair order for the very rare car that might have had them fitted by others.
BTW; HRE Wheels will use your wheel centers and create any offset that you might want. The 17" x 10" rears on my PCA Club Race car were done by them...the point in the video that you want is at about 1:15. Enjoy!
#42
