Can 928 100mm piston use on 911?
RL Technical Advisor
Nossir,.....virtually everything is different: piston shape, pin position, ring package, piston crown design.
If you want 100mm pistons, you need to either buy a set of Mahle 100mm P/C's or LN Engineering ones.
