Advice reindexing my 89 targa
Does anyone have any recommendations of a service specialist here in the Rhode Island area? I have changed the shocks to bilstiens and need to raise the car. I have been reading on how to reindex car but feel it would be a bit much considering balancing etc..
there are height adjustment screws that allow a limited amount of change. depending on where they are set now you may be able to raise the car a bit without re-indexing the Tbars.
but then you are still dealing with needing to corner balance.
I am going the other way on my DE/track car, need to re-index my Tbars to lower as the adjustments are already as low as they will go.
good luck.
good luck.
Parts Specialist
fronts should be a piece of cake but if the rears need done I would do it as close as you can before taking it in...its a laborious job and can add up in $$$$ get it close and your alignment guy can fine tune it
