911 Forum 1964-1989
Porsche Performance Upgrades
Old Sep 21, 2011 | 03:48 PM
911 Crazy's Avatar
911 Crazy
SPAM addict
From: Acadia National Park, Northeast Harbor, Maine
Default Porsche Performance Upgrades
If you had a 89' Carrera with the G-50 in it and $10k+/- to spend, what would you do to upgrade the performance? This should be interesting! Thanks again.
Tim (I'm gaining knowledge from you all everyday) Thomas
Old Sep 21, 2011 | 04:17 PM
Chuck Harmon's Avatar
Chuck Harmon
Lower it
Wong Chip
exhaust
strut brace
Old Sep 21, 2011 | 04:18 PM
Amber Gramps's Avatar
Amber Gramps
We've had this conversation many times and it's always a good one.
For me I''d have to say start at the bottom and work your way up.
Personally, the interior needs to be fresh and the ride needs to be smooth....but I'd start like this:
tires/wheels
brake rotors/pads
T-bars/bushings
Then you can move on to chip/exhaust/O2/etc...
There is no point in going fast if you can't stop it and control it.
http://www.rennsportsystems.com/1-sf.html
http://www.elephantracing.com/suspen...11packages.htm
Old Sep 21, 2011 | 05:20 PM
500's Avatar
500
Definitely suspension and brakes. An Elephant racing "street performance 1" suspension package runs about $2K (without installation). I would then allocate $2.5K towards new brakes (new or well-rebuilt calipers, new rotors, lines, pads) and tires. Assuming you do the work yourself, that leaves $5.5K, which I would invest in a motor rebuild savings fund. Eventually you will want to do the motor and ideally it will be a thorough build.
This is assuming all the normal things (like the clutch) are OK and the car is, well, err, umm... "sorted"
Old Sep 21, 2011 | 11:12 PM
911 Crazy's Avatar
911 Crazy
SPAM addict
Thanks to everyone so far. Am working with Steve Weiner at Rennsport in Portland, OR. Nice to get different ideas.
Old Sep 21, 2011 | 11:16 PM
911 Crazy's Avatar
911 Crazy
SPAM addict
500_19B: I am sort of looking for a "sorted out" 911.......sort of!
Old Sep 22, 2011 | 03:34 AM
The_Dolphin's Avatar
The_Dolphin
3.6 VRAM !!! That's it !
Old Sep 22, 2011 | 10:41 AM
Jay Gratton's Avatar
Jay Gratton
I like the suspension idea and some good tires and wheels, also get the brakes in good order. I then would start attending as many NCR-PCA DE and AX events as possible and learn how to drive the thing.
Tim Thomas? Like the goalie Tim Thomas?
Old Sep 22, 2011 | 10:55 AM
911 Crazy's Avatar
911 Crazy
SPAM addict
Jay: Will do on the attending events etc. On the latter, may be and then again may not!
Old Sep 22, 2011 | 10:56 AM
911 Crazy's Avatar
911 Crazy
SPAM addict
Jay: What is the deal with the wheels? Are the factory Fuchs not that good?
Old Sep 22, 2011 | 11:34 AM
g-50cab's Avatar
g-50cab
What do you plan on using the car for?
If just street driving - stock size fuchs and brakes are more than adequate.
I would definitely spend the money on suspension first (I did)
Then I would change the things I touch everyday - that means steering wheel, seats, shift **** (I actually like the stock g-50 ****)
If you plan on tracking the car - then I would look at 17" wheels (Zuffenhaus, Fikse or BBS) and upgrade the sways (tarrett) and bushings (elephant or rebel racing)
Engine wise - for a stock 3.2 - I'd make sure the valves are adjusted - then look at some george's European headers - and a dual in dual out sport muffler.
You'd be shocked how fast you can blow through $10K
Like Jay said - I'd set aside $1500 just for attending as many track days/autocrosses that you can - first investment should be the nut behind the wheel
Old Sep 23, 2011 | 04:32 PM
911 Crazy's Avatar
911 Crazy
SPAM addict
g-50cab: mostly a 2-3 day per week car with some light track use. I use to drive Formula Ford, Super Ford and a little Formula 3 in Europe in the early 80's. I know how easy it is to "Blow" through track $$$! This nut needs lotsa help!!! Thanks.
Old Sep 23, 2011 | 05:23 PM
g-50cab's Avatar
g-50cab
Then I would probably do suspension - nothing too crazy on the TB - maybe 22/30 - I'd change all the rubber to elephant racing PB or rebel racing. Strut brace (I like the integrated strut and monoballs) I'd get/trade for a set of 16 - 7's and 8's (205 and 225 dunlop dizurra (whatever they are called)... or send my existing 16's 6's and 7's and get them upsized to 17 x 7.5 and 17 x 9 from True Design - or similar, Tarrett sways on both ends.
Bolt in/bolt out rolllbar - maybe a few sets of brake pads and under a-arm scoops to keep them cool - then go and have fun.
Old Sep 23, 2011 | 06:06 PM
ricster's Avatar
ricster
A sorted car would look like mine. Re-bushed, new shocks, wong chip, exhaust, ssi heat exchangers, new turbo tie rods, ball joints, basically new everything and lowered, corner balanced.
Old Sep 23, 2011 | 08:27 PM
Busta Rib's Avatar
Busta Rib
suspension: bigger sways, TBs, new bushes, strut bar
seats (Recaros or other sport seat). the stock seats suck, imo
rennshift or Wevo shifter, bushings
3-spoke steering wheel
light-weight wheels (Fuchs are the best imo) and good tires
SSIs and new exhaust (it just sounds better). weighs less than stock too
chip
lower it, align, and corner balance
Once it is all buttoned up, enjoy the snot out of it.
