911 Forum 1964-1989
Random refresh pics....
Old Aug 1, 2011 | 10:29 AM
redridge's Avatar
redridge
Default Random refresh pics....
Though I might share some pics while I refresh my suspension and other tod things. I still have a ways to go but progress has been slow since the summer holidays has come.
ER rubber: A arm, Spring Plate, Strut towers and Trailing Arms.
Turbo Tire Rods
ER Tire Anti Rub Kit
Bumo Steer Kit
Bilstein Inserts Sports
Replace Wheel Bearings
Rebuild Calipers
Stainless Steel Brake line
New Bushing for Sway Bars
22MM Hollow TB
30mm Hollow TB
Lowered to Euro Spec
H4 Headlights and Relays
Refurb the fuchs 7 and 8"
More to come....
Old Aug 1, 2011 | 11:27 AM
Billm's Avatar
Billm
What did Porsche pot around the upper shock mounts (in the trunk) that shows cracks in pic #10 above?
Old Aug 1, 2011 | 05:23 PM
redridge's Avatar
redridge
not sure what you are asking, but it is sealant for the alignment screws. I believe it is just for some water proofing.
Old Aug 1, 2011 | 08:23 PM
Ed Hughes's Avatar
Ed Hughes
Suspension and brake R&R are two of the most rewarding and fun DIY projects on these cars, next to an engine rebuild.
Old Aug 2, 2011 | 09:15 AM
redridge's Avatar
redridge
I agree Ed, If you have the time and want to save some $$$, these projects are very satisfying... as for the engine rebuild. One day....
Old Aug 2, 2011 | 09:41 AM
ivangene's Avatar
ivangene
Parts Specialist
by rewarding I assume you mean finacialy draining !!!
Old Aug 2, 2011 | 09:46 AM
redridge's Avatar
redridge
Yes, its a fact.... they are all $20k cars.
Old Aug 2, 2011 | 10:30 AM
Ed Hughes's Avatar
Ed Hughes
That too!
I only wish that were true...
Old Aug 2, 2011 | 10:41 AM
ivangene's Avatar
ivangene
Parts Specialist
<fingers in ears>
<tongue making "LALALALALA" sounds>
I cant hear you
Old Aug 2, 2011 | 07:14 PM
redridge's Avatar
redridge
Ed,
What ever happened to the SSI, sports exhaust, intake, chip.... Did you ever install that?
Old Aug 2, 2011 | 08:48 PM
Ed Hughes's Avatar
Ed Hughes
Ed,
Im assuming you are asking the other Ed...
Old Aug 2, 2011 | 10:59 PM
ivangene's Avatar
ivangene
Parts Specialist
in the garage...I am on the fence on the install
Old Aug 27, 2011 | 02:36 PM
redridge's Avatar
redridge
More progress....
Need new bushings.
3 vise grip later…. separating TB and spring plates. Hammering out the vise grip to separate the 2 pieces.
Cause of sloppy suspension….
Cutting the 25 year old bushing.
ready for epoxy….
when inserting the new bushings with epoxy on the plate and rubber…. give it some twist while pushing it down.
all mounted up with new to me 30mm Hollow TB.
Now for some new bushing on the trailing arm.
Pry off the old bushings….. when doing so you will be left with a shell that is stuck on the trailing arm…. use a hack saw to release the stress of the pressed shell…. you don't have to cut very deep, just enough to loosen it up….like this.
Press in the new bushings.
Up next…. rear shocks, engine, tranny mounts and adjusting ride height...
Old Aug 27, 2011 | 02:41 PM
CT944's Avatar
CT944
Great pics. Did this job once myself. Looking back it was fun, though there were some frustrating times, mainly due to siezed nuts/bolts. Once you get past that, it all goes back together very easily and logically.
Old Aug 27, 2011 | 03:08 PM
Ed Hughes's Avatar
Ed Hughes
Memories....
I believe you're going to find the car to be underdamped with the new tbars. I'd spend the money now to have Bikstein valve the shocks to match. Sure, it will drive ok, but if you ever do revalve, you'll wonder why you waited so long-it will be that much of an improvment. I think it's only about $100 per shock.
