Winter oil recommendations
It's coming up to that time of the year when I want to do the prewinter oil change on my '86 3.2.
For the summer months ( and track days) it has Castrol 10-50.
During the April- Oct period the car gets out at least 3-4 times a week, because of the snow/rain/ slush/road salt possibilities around here during the winter it may sit for 1-2 weeks before an ice cold start/drive.
Motor has no leaks, burns very little(91K miles). I'm reluctant to go synthetic at this point.
Recommended oil for the winter? Thanks.
Technical Specialist
Lifetime Member
Lifetime Member
The current Porsche recommendation (June 2001) on oils for use in all 4,6, and 8 cylinder Porsche engines since 1973 is:
Castrol/Syntec......................... 5W-50
Mobil 1................................ 0W-40, 5W-40
Sun Oil/Sunoco Synturo Gold............ 5W-40
Texaco/Havoline Formula 3 Synthetic.... 5W-40
Valvoline/High Performance Synthetic... 5W-30
Viscosities recommended for the Turbo are 0W-40, 5W-40 and 5W-50. The nW-30 weight oils are approved to 85 degrees F. Greater than 85 degrees F should use nW-40 and above. Alan Caldwell (PCA Technical expert on 1989 and earlier 911's) has noted that conversion to synthetics in 1978 and later engines should not cause any undo problems.
I switched to Mobil 1 15W-50 in my 81SC at a bit over 100K miles, and didn't have any leakage or other problems with it.a
Lifetime Member
Lifetime Member
[quote]<strong> Does the synthetic offer any advantages during the ice cold winter starts? How about cooling during the 90deg plus track days?</strong><hr></blockquote>
I believe synthetics remain a pourable liquid to lower temps than standard oil, however they still have a range (5w-30, for example) where they are meant to work. On the other end, they do have a higher temperature where they break down, over dino oils (which is helpful in an overheating or hot running situation). I would recommend Mobil 1 15w-50 (or similar synthetic) if your track temps are up in the 250 degree range. If they're higher than 250-260, that's an overheating problem which needs dealing with. However, I wouldn't say synthetics cool any better than dino oils (cooling being more a function of oil coolers). Some have found their oil consumption is reduced with synthetics, as there aren't as many additives as in dino oils to burn off.
