F.S. 73 RS (R) Replica
PORSCHE 73RS REPLICA/TRIBUTE
.. $75-80k invested ....asking high $40s...located in NY...can work possible delivery
PM request for a complete photo portfolio.
Narrative:
The original chassis is a 1977 Porsche 911S VIN# 9117201571, in perfect condition
Registered and titled in the State of New York
I am the second owner of the donor car having purchased it from the original owner, a doctor , in 1994. The car has always been garaged, never used in the snow, absolutely free of any corrosion, and has never been damaged in any way. Even though it was not used in the winter, the original owner actually had Zeibart anti-corrosion applied. After I purchased the car the engine was rebuilt in stock form for PCA Club Racing events.
I used the car in its original factory stock form (H Stock) in PCA Club events for 6 races before beginning a project to convert it to its present form. The car has never been hit or damaged in any way. The stock engine was removed and used in a 914 project. It was replaced with a special build performance motor that I purchased from APCAR (see below). Steel 8 flares were added, steel front fenders have been retained. A fiberglass hood, front and rear bumpers and spoiler replaced the original factory pieces.
The completed project is a very aggressively tuned street replica; perfect for the track should you be so inclined. There are no track miles on the car/engine in its present form. PM request for a complete photo portfolio.
Chassis:
Back dated to the look of a 1973 Porsche 911 RS
Steel flares, steel fenders
Never dinged, nor dented, all gaps are perfect, as delivered from the factory
New Paint, Porsche color (original was brown)
Matter chrome-moly cage (PCA approved) chassis- welded by NASCAR licensed shop.
New windshield
935 rear view side mirrors
New 73 RS carpet and floor mats
Fiberglass hood
Fiberglass front bumper
Fiberglass rear bumper
Fiberglass spoiler
2300lb wet
Rennline solid Engine Mounts
Rennline Battery relocate kit
Optima race battery
Tilton lightweight starter
PVC headlamp covers
Fuel Safe 24 gallon fuel cell
New full leather sport seats
RS interior panels
Engine:
3 liter, 100 x 66mm crank shaft
930 Turbo aluminum case
Carrillo rods, Mahle pistons
10.3 compression
Dual plug heads
906 camshafts w/true center oiling
Nirosist rings
Electromotive Tek1 engine management
TWM throttle bodies
TWM Air horns
ITG Air filters
7800 rpm
Mobil 1
225hp at rear wheels (approx 280hp at flywheel)
Dyno tuned and tested ( copy available)
Dansk sport muffler
Two, front bumper mounted and one, drivers side oil coolers
Less than 2 street hours on engine since top end (dual plug) rebuild
Transmission:
Stock Porsche 915 disassembled and serviced by PowerTech
Wevo shift and linkage
Brakes
Front VCR floating discs
Front Porsche 930 Turbo calipers
Rear ventilated 930 Turbo disc and calipers
Rear 930 Turbo calipers
Suspension/Steering
Bilstein coilovers front and rear
Weltmeister Antiroll bar front
Weltmeister Antiroll bar rear
Rennline front strut bar
935 rear camber plates
930 tie rods
Bump steer kit
Wheels/Tires
Fikse FM-10 8.5 x 17 front
Fikse FM-10 10 x 17 rear
Yokohama A032 235/40-17 front
Yokohama A032 255/40-17 rear
Narrative:
Chassis:
New windshield
Fiberglass hood
Fiberglass spoiler
2300lb wet
Optima race battery
PVC headlamp covers
RS interior panels
Engine:
10.3 compression
Dual plug heads
Nirosist rings
TWM throttle bodies
TWM Air horns
ITG Air filters
7800 rpm
Mobil 1
Dansk sport muffler
Transmission:
Brakes
Suspension/Steering
930 tie rods
Bump steer kit
Wheels/Tires
Can't seem to pm you
Can you email pics to mikeszabo58@gmail.com also your number
Sorry pm wont work for me
