Pedal Cluster Rebuild
Just received a Weltmeister bronze bushing kit to rebuild my '88 911 Turbo pedal cluster. Everything fits fine. But the kit didn't come with a replacement spring spacer (16mm long x 14.5 mm ID). This slides on the clutch pin/shaft on the right side (nearest the center tunnel) of the cluster.
The existing spacer is white plastic (?) or nylon and doesn't appear to be worn. Should I reuse this piece and if so, can it be lubricated using grease as the other bronze bushings without causing it to swell? Is there a bronze replacement for this piece.
If anyone has experience with this situation, any info would be appreciated.
Thanks,
Brad '88 911 Turbo
Thanks,
Brad '88 911 Turbo
