911 Forum 1964-1989
Cylinder Head temp sensor Install
Old Feb 20, 2002 | 09:42 AM
gerry100's Avatar
gerry100
Post Cylinder Head temp sensor Install
Looks like a new CH temp sensor might be worth a try to solve my intermittent stumbling problems-
Any tips on installation?
I can see it and touch it but that doesn't mean it is easy.
Thanks as always.
Old Feb 20, 2002 | 01:00 PM
john walkers workshop's Avatar
Post
once you have exposed it, cut off the wire and use a 13mm deep socket to remove it. the new ones are 14mm wrench size and difficult to tighten without a custom socket. i took a 14mm deep socket and cut a 10mm wide slot all the way up the side with a disc cutter. the slot is for the wire. be careful not to tighten it too much or it can break off in the head. wet style silicone spray lube on the rubber grommets helps a lot.
Old Feb 20, 2002 | 03:48 PM
Clark Griswald's Avatar
Clark Griswald
Post
Here is a link to pics and tips from when I replaced mine.
<a href="http://www.pelicanparts.com/cgi-bin/vb/showthread.php?s=&threadid=6578&highlight=head+sensor" target="_blank">http://www.pelicanparts.com/cgi-bin/vb/showthread.php?s=&threadid=6578&highlight=head+sensor</a>
Good luck, it's not too tough.
Old Mar 10, 2002 | 11:00 AM
gerry100's Avatar
gerry100
Post
Just a note to say thanks to Clark Griswold-
Your effort to put together the pix and notes on this project were invaluable.
I'm a garage floor mechanic, and would still be figuring this out without your help.
The time you put in will give me and others more "seat time" and less floor time.
thanks again.
