Final airbox fix
Does anyone remember what the final factory airbox fix was?
I remember replacing the one in my 78 911SC and installing the pop-off valve just as insurance. I later learned that the replacement that I bought from the Porsche dealer was the final solution.
By the way, I once saw a 911 with a pop-off valve installed on the airbox ledge free to the open atmosphere. LOL
When I replaced my exploded airbox last year, the new one was different but I don't know whether it was the "final" fix. Rather than having the cold start fuel just spray into the airbox, the new one has a sort of "mainfold" (a network of metal tubes) which directs the fuel into the intake pipes. I was told that this was done to make airbox explosions less likely. Regardless, I put in a pop valve as well - I don't want to go through that exercise again.
Technical Specialist
Lifetime Member
Lifetime Member
There was not a really final fix. As Bryan points out, there was an update around 1980-81 to better distribute the cold start fuel, and as far as I know, that's the only box available as a replacement box today. Adding a pop-off valve maximizes longevity.
![Arrow](https://rennlist.com/forums/images/icons/icon2.gif)
I think Bill is right.
However, at one time there was an all aluminum unit that was sold (NLA). THAT was a final fix (if anyone knows of one laying around drop me a line - I know of a supercharged SC that could use it).
I think the all aluminum one was from one of the aftermarket sources. When my airbox blew I ordered one but it was such a poor quality casting and a really poor fit that I sent it back.
It looks as if the "final" factory fix was the fuel distribution manifold within the airbox.
One thing to keep in mind when doing the pop-off valve is the epoxy used. The epoxy included with the kit is good, but not as good as it should be. On mine, the epoxy dried up and on a backfire one day, blew the pop-off out. I have found that wurth epoxy, which comes in a little mixing cup, is superior like all wurth products and works much better. You can get it from any mechanic that buys from wurth.
Lifetime Member
Lifetime Member
[quote]<strong>One thing to keep in mind when doing the pop-off valve is the epoxy used. </strong><hr></blockquote>
Ed, good point. I used JB Weld epoxy when I installed mine, noting it has a high temperature rating.
