Detailed Engine Pics (911SC-Turbo)
Poseur
I finally got around to scanning a bunch of slides that I shot back in 1987 of an engine rebuild to my 1981 911SC that had been turbocharged.
Some of the work was done to enhance it's performance as a turbo motor, from the days when it started out as a normal 3.0 SC CIS motor. Things like piston crown sprayers were added (look closely!) and the cylinders were shimmed out further to effectively lower the compression ratio so that I would not detonate with premium fuel. (Prior to that I had to run premium and ST104 at all times).
The answer was this engine. It performed extremely well. It was clearly producing about 270 hp (vice the NA 172) with a modest boost of 6 lbs.
The intent of this posting is to help some of the newer to air cooled 911s understand how these things are put together. You will get a chance to see things like the chain tensioners (latest 3.2 Carrera ones--oil fed). Also, you may see a pressure relief pop-off valve within the air box. Of course, it had to be disabled when you have a turbo motor because it would never stay closed! (A liberal amount of GE silicon did the trick).
Builder was Sam Flippo, former owner of BRI Imports in OKC. A tremendously talented businessman, engine builder, and Porsche race car driver.
Poseur
Hey Clive, see where he put the dip stick? ![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
I still can't wrap my head around the CIS engine. Way too complex for me. The 3.0 era I just fog up upon thinking.
The long block pictures however are pure ****.
