OT. Never knew just how much automotive fluids I had lying around...
until I built some shelves to organize them. I'm slowly getting my garage in order so I can have some space to take up some big projects: 1. Head stud replacement on the 1978 911 and 2. Restoration of a 1964 356C coupe. These are the projects before the projects. LOL
Tadaahhh. My latest welding triumph. 10 in. by 8 ft. shelves to fit the space available behind the garage's man door and between the 911 and the wall. I looked at commercial shelves, but everything is 1 ft. deep. Too big.
![](http://i56.tinypic.com/1zojb4m.jpg)
Then, I started putting my fluids on the shelves... and, almost half of them became occupied.
![](http://i54.tinypic.com/oarvkl.jpg)
Each shelf section is 4 ft. wide. That's 16 linear feet of fluids. (OK, almost 1 whole shelf is used fluid waiting to go to recycling, so that will clear out soon... only to be replaced.) Before starting, I figured I'd fill two shelves with fluids. LOL I've cleared a lot of floor space this way.
Definitely cool to make much better use of this wall. The before pic:
![](http://i55.tinypic.com/295fg4j.jpg)
I now have something I've never had. A surplus of shelf space.
And the 911 continues to gather dust as I now have to appease the boss with returning to unfinished projects inside the house.
![](http://i51.tinypic.com/2a0c9du.jpg)
She just doesn't get it. I really needed that 4 month "garage therapy vacation" away from the house projects. LOL
Brett
Brett
I would expect you to have a hazardous chemicals permit. ![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
But, seriously have you included any wall attachment to keep the chemicals from falling in the event of an earthquake? Plumbing type straps near the top of the shelf structure that are anchored into a wall stud. Also, some type of preventive barrier at the front of the shelves.
Consider other strategies for things above your prized cars. You never know.
Good point about securing items above the cars. The shelves are bolted to the wall. I have thought about securing the stuff on the shelves. Thinking about welding tabs at the front of the shelves that I can stretch bungee cords between.
Brett
After 2 down-to-the-studs bathroom remodels, I had scrap plastic and copper pipe building up along with 2x4 and other wood bits and now other metal scraps from the metal projects. I had it all leaning in that corner already, so I just thought, "Well, let's make it official." I think it works well... until the bin gets full, anyway.
Brett
I don't know. PO did it. I'm thinking it's a urethane paint. Pretty sure it's not an epoxy. I believe it must have been done when the place was put on the market as a "quick and dirty" beautification because it looked pretty fresh when we moved in. It's not a durable coating as I've marred it up pretty good in the 8 years we've lived here. The pics don't tell the story. It's a 20-footer paint job now. Chemical resistance is very good, though. Oil spills wipe up spotlessly with a little solvent. There is some grit tossed in it, but it is quite slippery when wet. I'm undecided whether I'd refinish with something similar or do an epoxy when it comes time to recoat.
Brett
Brett
