This 7R case weldable?
What do you guys think?
BTW, good idea to keep the water drained out of the case. I felt like a dentist pick, picking away at these suspicious spots until the holes opened all the way up
Last edited by EastBay; 01-28-2011 at 09:53 PM. Reason: added a bigger view picture
Team Owner
no idea what this is ,is this from a 911 or a 996?
a 996 rusting out like that ? wow ..maybe somepics from further back , and youmay want to put them in the 996 forum
An SC case isn't the same as a this. Where's this 2.7L project going? I guaran_______tee you that if this 7R were from a '73RS, you'd fix it. For a generic 2.7L car, just find another for a few bucks. I might have one or two good ones. I know I have one that had a crappy timecert job done you could have free. No guarantees.
3.0 SC motors are easy to find and make a nice retrofit into the midyear cars. If you are looking for concours originality; look for any other of the multitudes of 2.7s laying around.
Poseur
Move to an aluminum case. Porsche really screwed up big time for several years when they attempted to shave some weight off the cars by using magnesium cases instead of aluminum. It nearly cost them their business! With the arrival of the 1978 911SC they finally fixed the problem with an aluminum case. Many have chosen to update their 2.7 litre 911s with the 3.0 911SC case. As you can see, magnesium has a problem with corrosion.
But back to the architecture of the engines. Not going to drop a 2.4/2.7 style 70.4mm stroke crank in an SC case. And the factory did produce aluminum cases starting in 1974; some oddball version of the car called the 930. Then, a year later, lo and behold a normally-aspirated 3.0 came on the scene using the same crankcase. But if you want to remake your 2.7 into one of those, sure the crank (and everything else) will fit, except you'll need 95mm cylinders.
