1989 Porsce Speedster Oil Leak
Wanted to see if anyone can advise on what the correct fix should be.
Looks like it is leaking from oil galley plug.
That is supposed to have an epoxy over it, and JB Weld is what is commonly used on cases that are cleaned for a rebuild. There are a couple of other spots that get the same treatment. Was that engine rebuilt? If not, who would have cleaned the material off-it looks like it was done recently-too shiny to me.
I wonder how tough it will be to get anything to seal there now? It may be the engine needs to come out and be inverted to seal it right. Only time will tell....
Have faith my brothers..
Drain oil.
Clean the area.
Very lightly roughen up the plug and surrounds with 120 grit paper.
Wipe down with a clean cloth with Acetone or thinners.
Apply JB weld.
Let cure for correct time.
Refill oil.
Flog **** off it.......
Drain oil.
Clean the area.
Apply JB weld.
Refill oil.
