911 Forum 1964-1989
Oliver's '89 powertrain refresh thread
Old 03-16-2011, 10:08 AM
  #31
Ed Hughes
Ed Hughes's Avatar
Originally Posted by Scott C
The engine and trans are bolted back together. The release arm insertion was a little weird but no biggie.
I've got everything ready for the engine/trans re-installation. Hopefully will happen tomorrow night or it will push to next week due to work, etc.
I'm really looking forward to bolting up the Stage 8 fasteners on the CV.
Ed, have you installed yours yet?
Get that puppy running!
Sorry to say, I've not touched the fasteners.
Old 03-16-2011, 11:04 AM
  #32
rusnak
I haddah Google dat
rusnak's Avatar
Looks like a very nice job! Make sure that your flywheel has a ferrous ref pin!
Old 03-16-2011, 09:01 PM
  #33
User 4221
User 4221's Avatar
Here's a pic of the engine ready to be installed...... Ed, note the new engine mount!
Rusnak, I checked it three times.... I don't want to have to go back in.
And here's a shot of the transmission...... I bit the bullet and had a shop go through the box. They replaced all syncros, needle cage bearings on 4th gear and the output shaft bearings.
Old 03-16-2011, 09:22 PM
  #34
2specs
2specs's Avatar
Very nice.
Old 03-16-2011, 11:04 PM
  #35
Ed Hughes
Ed Hughes's Avatar
Well??????
Old 03-17-2011, 12:36 AM
  #36
User 4221
User 4221's Avatar
Sorry, Ed. It will wait until next week. This work thing is really getting in the way of my wrenching time
Old 03-17-2011, 12:58 AM
  #37
rusnak
I haddah Google dat
rusnak's Avatar
Hey I think you missed a spot on cleaning. No you didn't, that's a spec of dust on my monitor.
Old 03-17-2011, 01:02 AM
  #38
shadopadla
shadopadla's Avatar
I wish mine looked that clean...
Old 03-17-2011, 04:42 PM
  #39
User 4221
User 4221's Avatar
Now I have to clean the rest of the underbody to match the trans.......
Old 03-17-2011, 05:11 PM
  #40
Amber Gramps
Amber Gramps's Avatar
Old 03-29-2011, 12:23 AM
  #41
User 4221
User 4221's Avatar
Finally! I got her buttoned up and on the ground last night.
No leftover or missing parts!
I pulled the DME and cranked to build pressure. After a few seconds of cranking, the oil pressure light went out and the gauge was showing about 2 bar.
I installed the DME relay and cranked again. After a few seconds of cranking, she fired up. The car idled perfectly and was very stable. I quickly found a small fuel leak on the "J" hose connection. After fixing it up, all was perfect.
I let the car idle a bit and shut her down.
Today I fired her up and went for a spin at lunch. The transmission was a little clunky at first, but once I ran through the gears a few times, it began to shift very smoothly. The 4th gear whine is also gone.
I took the car for a state inspection/smog this evening. All emitted levels were no more than 25% of allowable levels..... Passed with flying colors.
I'll post pics and video tomorrow.
To summarize the work done, here's a list.
Transmission stuff
- Clutch
- Pressure plate
- Release bearing
- Release bearing arm update
- Flywheel
- Flywheel bearing
- Flywheel seal
- Slave cylinder and hose
- Transmission refresh (New synchros, 4th gear needle bearing and differential output bearings)
Chassis
- New soft rubber brake lines
Engine - Fuel injection
- Engine speed sensor
- Reference sensor
- 2-Wire CHT sensor
- Fuel injector service
- Intake rubber boot
- New fuel lines (all)
- New vacuum lines and venturi
- New brake booster vacuum line
- Fuel filter
Engine - Oil
- Oil pressure sender
- Oil temp sender
- Oil pressure switch
- Oil temp switch
- Engine oil cooler clean and test
Engine - Seals
- Oil thermostat O-ring
- Intermediate shaft seal
- Intake gaskets
- Intake spacers
- Timing chain cover gaskets
- Tensioner O-rings
Engine - Misc
- Valve adjust
- Muffler gasket
- Engine mount bracket
- Motor mounts
- S-hose
- Tensioner oil lines
- O2 sensor
- Plugs
- Distributor cap
- Rotor
- Fan belt
Work - Misc.
- Cleaned engine thoroughly
- Cleaned fan with buffing wheel
- Cleaned engine tins
- Stage 8 half-shaft bolts
- Heaterbox - Exchanger hose
- Adjusted rear bumper alignment
- Added tether restraint hook for Oliver's car seat
I'm sure there is more, but this is all I can remember. I keep telling Oliver that the next time the engine comes out, he can do it!
Thanks for all the help and feedback, guys!
Old 03-29-2011, 12:30 AM
  #42
rusnak
I haddah Google dat
rusnak's Avatar
Many cans of Brakleen died so your engine could live a clean life.......
Old 03-29-2011, 12:38 AM
  #43
User 4221
User 4221's Avatar
Only two cans of Chain Clean from Motorex and some Simple Green + Lots of elbow grease.
I think I killed a small forest by using the blue paper towels.
The Chain Clean cleans grime without attacking seals..... Especially the through-bolt O-rings.
http://www.motorex.com/index.cfm?oid...&eintragId=106
Old 03-29-2011, 01:16 AM
  #44
Ed Hughes
Ed Hughes's Avatar
Excellent
Old 03-29-2011, 12:31 PM
  #45
User 4221
User 4221's Avatar
The emission numbers looked really good..... Here are the results
Quick Reply: Oliver's '89 powertrain refresh thread
