911 Forum 1964-1989
Dummy dash lights flash_1990 911
Old Dec 14, 2010 | 05:54 PM
randallfowler's Avatar
randallfowler
4th Gear
Default Dummy dash lights flash_1990 911
Hello to all... first post.
I have a 1990 964 C2. Every so often when driving (seems to be getting worse) all of the 'dummy' lights on the dash come on then go off. Once in a great while they come on and I get a on and off beep and the only way I can get the beep and the lights to stop is to turn off the ignition and then back on. Anyone had this problem? Thanks in advance!
Old Dec 14, 2010 | 06:15 PM
Amber Gramps's Avatar
Amber Gramps
Randall, welcome to Rennlist.
Just below where you found us you will find your fellow 964 guys. They may be better equipped to help you.
Old Dec 14, 2010 | 06:28 PM
ivangene's Avatar
ivangene
Parts Specialist
might be an ignition switch but the 964 guuys have better data to go on than us
Old Dec 14, 2010 | 06:41 PM
randallfowler
4th Gear
Thanks ivangene... i have posted it on the 964 forum. I have seen a post or 2 mentioning that if you have 100+ on these older cars that an ignition switch change is 'good prevent mant.' even if it does not fix a certain problem.
