In Case You Missed This In OT...
I had to do the CA required bi-annual smog test about a week ago. My car is an '82 SC equipped with o.e. cat, functional Lambda, and 203,000 miles (never rebuilt) on the clock. The guys at the test center were definitely impressed (they told me two tests ago that it runs cleaner than a four year old Honda)!
![](https://rennlist.com/forums/attachments/off-topic/492244d1290873714-how-clean-can-a-28-year-old-scan0065.jpg)
About 1500 miles and 2 1/2 years since the last valve adjustment. I had an injector fail about 1,000 miles ago; all that I did was diagnose the miss (found a dark spark plug), replace the injector and take the car for a blast on the freeway. The car is absolutely consistent with the way it runs, and I make sure it gets a sip of Stabil when it has to sit for a while.
Your car is living proof of what a big difference diligent maintenance makes in the long-term.
I'm just glad we don't have that testing here (yet). I'm all for clean running, well tuned vehicles and my junk usually runs well (now the Ford bronco might worry me at a test).
However, if I did have to get smog testing, I would certainly go to "Best Smog"...I love that name.
Poseur
It's funny too, it wasn't a bad fail. Instead of a nice umbrella pattern, it kinda peed out one side (and the umbrella was still intact on the other side); just enough to mess with the spark plug at idle/low revs.
then you found a plug...what diagnosis did you go thru? where you looking for a problem when you found the plug, or was the plug change a mesure of mainteneance. Did you go straight to the injector? Reason I ask, is because I accidentaly found injector issues(similar to your minor drivability description) that led me to replace all four...yes this is my 924S. Car has run flawlessly for 35K miles since. I could,at times, detect a slight knock. Compression was good, oil pressure was good...I was leaning toward wrist pin. Tore it apart this past september and found the pistons were worn on the skirts below spec and I suspect the bores are equally damaged althought I haven't bore-gauged them yet. As I have stalled on the project, pistons are as much as a set of mahles for a 911 plus alusil block bore etc. The whole things totaled as far as I'm concerned so I am searching for a GOOD used motor to get it going - it's a daily driver. GOOD is hard to find in 944 2.5/2.7 circles. Point being, I think the cylinders were washed down from bad injectors and now I'm in a tough spot deciding what to do. If in fact I am correct in my theory on this...LOOK at your injectors people. My 924S injection is very much the same as a 3.2 Carrera, Peter's SC is a different animal injection wise, but I feel it's prudent to have this sorted on our older cars.s
Peter, wish my 83 was in the same boat. Last smog test my “special smogger” took about 40 minutes on the machine to get the numbers he needed.
I have wondered if you still had the car—red is it not? I think everyone was happy when you decided not to sell it. I remember the frantic posts of “keep the car” Pete. Mob rule in this situation was happy.
Hope all is well with you and yours. .
Yep, I kept my SC, and then put spoilers on it and switched insurance policies so my wife can drive it to work once in a while.
I had to get an '85 ZZZ smog tested on a rolling dyno a few years ago. I had just bought the car in another state and had not had time to fool with it.
The first test it failed, but not badly. Then I tuned it, changed the oil, and put on a new non-OEM cat. The second time it passed with amazingly good numbers.
As Peter points out, with good basic care a Porsche does fine on smog.
I haddah Google dat
My friend's 82 sc failed w high hc yesterday. I told him to check his ignition wires and check for a loose spark plug because the tech said the mixture was good and there was no miss. The coil wire was almost completely loose.
This thread makes me want to check the injectors. Do you guys run the fuel pump (jumper) w engine off to check injector spray pattern?
