SC min. br. rotor thickness?
My pads are definitely due for replacement and there's quite a lip arourd the outside of the rotor. What is minimum thickness before I can no longer machine the rotor?
I'm not real picky on pads, but performance parts has 20% off everything for fathers day and looks like their selection of pads is Ferodo, Mintex or PBR. Any comments on these three?
Thanks.
Thanks.
I am currently running ferodos on my sc and have been pretty happy with them. They do however seem to be rather dusty, but they work well when they're cold and in the rain. I had metalmasters before the ferodos and was not as impressed with them. The ferodos do squeal every once in a while by the way.
new thicknesss is 20.5 - 0.2 mm, min., thickness of disk after machining is 18.6 mm, wear limit(for symetrical wear 18.0 mm (1.0 mm per side), lateral runout max. 0.05 mm
