Any ideas on this.
I haddah Google dat
I like BG 44K for cleaning dirty fuel systems, but nothing is as good as sending them in or replacing injectors. +1 not a good idea to exceed manf prescribed concentration.
A lot of fuel pumps have failed due to our sh+tty gas nowdays. And cis has those iron FDs......
I would be curious as to fuel pressure.
For the sake of info, what would cause this (as related to the Techron)? (that is, on a technical level).
Trust me, Ed. I've learned,..no more,...no more...(bet those injectors are as clean as can be, barring send out to a rework company. I'm considering, as their 21 years old......I wouldn't think they act "as fine wine would"....
As always, THANKS!
Best,
Doyle
I plan to get the fuel leak fixed,..attach a brand new fuel pump,..then quanity my pressures (all of 'em) as a start baseline kinda' thing.....as well would hope to get these same measurements BEFORE the changeout so as to quantify my present 21 year old arrangement....before touching it.
Many thanks!
Doyle
I haddah Google dat
That's why you don't use too much.
Doyle, you can use a fairly simple fuel pressure gauge and jumper the dme socket to run a quantity test.
i d about what
Hey muss, check fuel pump fuse and terminals for tight fit. They all melt, even the wire into and from. If that terminal is good then go to fuel pump relay terminals. Remove relay and check for tight fit. (two fuel pumps = two red relays ) they melt with out prejudice also. As for the thechron , unlike 6k other things, It works. good luck and safe motoring MJ>
uninformed gas bag
(contemplating on whether gas bag is one or two words)
I was messing with it today. Runs ok then the idle comes down and coughed and sputtered but still ran. Pulled the front pump relay and it quit. Put it back in and pulled the rear relay and ran the same. I think its rear pump wiring or the rear f pump is on its way out. I will get into it tomorrow. I ran out of time today.
