Blinkers on the blink
6th Gear
For the last couple of mornings, I drive to work and the turn signal indicators (on speedo) blink rapidly (both sides). I get in the car to drive home (considerably warmer outside, hmm) and the signal indicators work fine. At this point I have not had either the foresight or the presence of mind to check if the actual signals are working, so forgive me for omitting what is probabily the most important detail . Thanks for any input!
Matt '80SC
Matt '80SC
Matt,
I dont know if this holds true with Porsche. My daily vehicle (Acura SUV) was doing the same thing until my brother called me stupid and told me to fix the light that was burnt out. Apparently some sort of warning letting you know that a bulb is burnt.
With the blinker on, go to the offending signal and gently tap on the lens cover. If the signal suddenly works better you have a corroded socket/bad ground.
Fast signals indicate that one of your blinkers do not work.
Replace your bulbs with Jahn or Phillips to maintain correct current. Do not use standard US bulbs.
Jw
Jw
6th Gear
All good advice, but the issue is that they blink rapidly in BOTH directions. Usually if it's a bulb issue it will only blink rapidly on the affected side... Furthermore, I'm concerned by the fact that they (indicators) blink rapidly in the morning and regularly in the afternoon, thus indicating a poor connection that's heat sensitive somewhere in the car. Where would that connection be?
Do you park your car outside, or in a garage that gets wet? It may not be heat, but rather condensation driven out by the average day's heating up and evaporating the moisture.
Here's an exercise I would perform regardless of your current problems: doing this really sharpened up the car's nightime lighting. I would spend the weekend with a package of European-spec. bulbs, pulling the blinker assemblies, cleaning the assembley silver backing with lukewarm water (for a nice refractive backing), soak the lenses in hot water and toothbrush out the dirt, reassemble with new or cleaned bulbs (ALL Euro.), and fresh gaskets or use 3M sealer, in black, to help seal up the assemblies.
No guarantee it will solve your (relay?) problem, but certainly a worthwhile way to spend an afternoon.
Jw
Jw
