high-frequency vibration in front of SC
I think I have a wheel bearing going out on my SC. I feel a real slight grinding/high frequency vibration in 60mph+ sweepers. Is there anyway to tell without disassembly. What are other possible causes of the problem. If it is likely to be a bearing does anyone know where I could find the procedure? Are any special tools required? I have seen the bearings for $10 and $20 apiece for inner and outer. If it is one bearing should I go ahead and replace all 4 in front. As far as I know they are the original 20 year old bearings. Thanks in advance.
