OT. Building workbench. Wood or metal? Update: Metal bench done
I'm thinking I'm going to build a small bench for some more workspace and a place to mount a vise. Dimensions probably 5 ft by 2 ft. I've only worked on wood benches, but now that I have a welder I have the option of making it out of metal.
Just seeking thoughts and commentary from your experiences. This is definitely not an ultimate workbench build. Just a simple flat top. Probably open underneath for stowing large items, or I might incorporate a shelf underneath.
I think I'm looking for reasons that I shouldn't use metal. Advantages for metal that I can think of: chemical, scratch, heat resistance, easy to weld on custom brackets or holders for specific items in the future, might double as a conductive welding table, fun welding project...
I could also mix material. Wood frame/metal work surface or vice versa.
Or maybe I should just go to Sears and buy one of theirs. I haven't actually priced materials to see how my cost would compare. Thoughts?
Brett
Brett
I like the metal frames.
If it's going in a position where you can weld without fear of sparks and grinding dust, (grinding and welding go together) flying around, I'd do a metal top. If not, very thick timber.
I have built half dozen wooden benchs, thay are all still in use - in productive shops after years of use. I get the Simpson metal braces from the big home stores and frame them with wood. I use the brace at the corners for a 4x4 leg, and the top/shelfs are 2x4. The one I am using in my shop now is using the said brakets and solid white oak for the structure instead of crappy pine (which works very well). The top is 3/4 plywood and can be removed/replaced. You can custom size them as well. Mine is 6ft x 2 ft. Others I have made were 3ft wide and much nicer as a work surface. 2ft is quite shallow. I'll have to get some photos, but the shop is a mile away and its raining, I will snap some asap.
I have a 7'x3' wood one that my brother built for me 15 years ago & while I'd hate to have it ignite with all the crap that's been spilled on it, truth is it's never let me down! If I was doing it all over I'd top it with metal because then you could wipe it down easy.
I haddah Google dat
There's just something warm about working on a traditional 2 shelf wooden workbench. I think the material used is probably less important in the end though, than other stuff like lighting, space, organization, power outlets, etc.
You can never have enough benches.
I have 8 work benches in my tiny two-car garage. Three are steel and five are wood. I made them all.
With no 911:
I have one welding bench that folds down from the wall (and a woodworking one that folds down, too).
Up:
Down:
Here's another view. The bench with the vise on it has an inch-thick top. Moving it into place was a pain in the neck.
The butcher-block for the bench in the center came from Ikea. The one in the back is a solid-core door. I used a roll bender to bend the lateral support for the butcher-block-topped bench at the opening of the garage.
Did I mention I like benches?
And yes, the garage gets dirty. Last month, we swapped a different engine into the 911:
With no 911:
Up:
Down:
I bought an 8' L x 3' wide work table from Costco for $200. It has a metal frame and the table top is hickory at least 3/4" thick. I figured it would cost me much more to build something like that. Now I have a bunch of power equipment on it....so not sure what the point of that was?!?!? IN other words, my garage looks at LEAST 3 magnitudes more cluttered than Jack Olsens.. I need a bigger garage.
I miss my 36" X 96" wood workbench I had in Texas. It was just too big to move.
I went the easy route when we moved back to Calif and went with a Gladiator bench which is quite heavy, sturdy and solid, but that was only for convenience as I wanted to get my garage secured quickly. Not the same as building a bench, which allows customization and the reward when done.
Thanks for the comments. Couple of you have me rethinking wood. I'll have to check out the braces mentioned. Maybe a nice sturdy wood frame with a slab of metal on top.
Brett
More OT. I've got a lot of OT to go through to get my garage sorted before I can get back on topic with dropping the engine of the 911 for head stud replacement. LOL
Just some pics of progress on the bench. I settled on my original metal bench thought. I've already got a small pre-fab formica-topped wooden bench stuck on one wall. After surfing the web and seeing all the ingenuity displayed by guys who built their own welding tables, I decided I had to do metal. It's also very good and very necessary welding practice. I love this welding thing. Everyone should try it. LOL
The bench will go on the other side of the 356 where the bike is. The grey slab is the 1/4 in plate top.
The 911 awaits attention. It's been sitting 2 years. It's a little dusty.
Brett
Brett
I haddah Google dat
Oh.
My.
God.
Finally......finally someone else other than me with Porsche projects in limbo or indefinite hold, with a man cave that actually looks like a cave, not something out of Better Homes and Even Better Garages.
Brett, you made my week.
My.
God.
I cheated on one of my work benches, picked up a used wrought iron fish tank stand for free to use as a base. Since it was used to hold a heavy 60 gallon fish tank I figured it would be strong enough for my needs.
John
