Rear Loudspeakers
![Cool](https://rennlist.com/forums/images/icons/icon6.gif)
I have a loose connection on one of the rear loudspeakers, which is driving me crazy. I am wondering how in the world do I access them! Can anyone help me here?
Initially I want to just plug it in again, I may replace them (I think they are quite crappy)
TIA <img src="confused.gif" border="0">
Do you have surface mounted plastic covers, Carlos or are the speakers themselves concealed and mounted UNDER the perforated vinyl lining? If they're mounted under, they're also actually fixed to the underside of the lining panel. You'll have to remove this rear panel - not completely, just enough to elevate it sufficiently to poke your head under to get at the speakers underside connections and nip the connector up a bit tighter. I had to remove one of the side sill trims to make it easier.
