DISTRIBUTOR ADVICE NEEDED....
In my quest to re-do my ignition system, I've run into a road block. My car, a '73E, has a 2.7 engine, which uses a '67 case, I'm told.
In getting the number off the distributor, I discoverd that the distributor is from a 67T and L. Uh oh!
The engine has Weber IDAs, Solex grind cams, if I remember right, SS heat exchangers, and a sport muffler. Roughly 9.0 compression.
So...what is the appropriate distributor? And a good source for it? I would prefer post '72 items to allow the option of the Pertronix Ignitor.
Thanks in advance for any help!
I bought one of the first 911 Pertronix units that came out. I had previously gone thru point sets like crazy. I was always wearing out the rubbing block and chasing the timing. After I installed the Pertronics I never had to mess with the ign timing again. It was great.
PET says the distributor for you engine should be 911.602.021.03
