Another newbie question: upgraded wheels
OK, so I'm looking at an '87 and it has 17" aftermarket wheels with spacers. What effect does going to a larger rim size have on:
- stock suspension set up
- odometer calibration
- other stuff
Thanks!
- other stuff
Thanks!
Odo depends on tire diameter. The rim size has nothing to do with OD. Larger rim sizes usually get lower profile tires. The ride will be a little harsher. 17" typically gives a bit wider choice in rubber. Wheel bearings take more punishment with spacers.
Spacers suck, the wheels were not made for the 911 offset if they are required. This can be remedied, although you may spend a few $ for proper wheels.
Guys- again, thanks for the help & especially, Ivangene for the link! I'm really looking for a well maintained, low mile, stock car so yeah, deducting for non-stock items like wheels will be a given.
If I'm understanding it right, assuming the O/A dia of the wheel is larger than stock not only would it affect the speed reading wouldn't it also affect the odometer? Wouldn't odo show fewer miles than actually driven with larger wheels?
