911 Forum 1964-1989
Porsche early A/C design tutorial...or NOT.
Old 08-30-2010, 12:52 PM
wwest
wwest's Avatar
"...lower is better.."
But wouldn't that result in a longer duty cycle for the compressor, running a higher % of the time vs high(er) pressure...??
Old 08-30-2010, 01:06 PM
griffiths
griffiths's Avatar
The time that the compressor operates, on your model, is based upon the thermostat. How many hours a year do you think your compressor clutch will be engaged?
Old 09-02-2010, 08:42 PM
Mazinger
6th Gear
Mazinger's Avatar
Thanks, but question:
When the evaporator makes the "Shhhhh" sound, is this at the same time when the compressor runs?
Old 09-02-2010, 09:11 PM
griffiths
griffiths's Avatar
I could not tell you without hearing it, that sound could be anything from air moving through the coil, the evap fan motor, a leak, ice (moisture) in an expansion valve.
Old 09-03-2010, 12:43 PM
wwest
wwest's Avatar
I only really hear the evaporator "sound" shortly after shutting the engine down and the remaining liquid refrigernat continues to exhaust into the evaporator via the expansion valve.
Old 09-04-2010, 01:10 PM
Mazinger
6th Gear
Mazinger's Avatar
This sounds scary
It's cooling though, If it goes south we'll look into it
Quick Reply: Porsche early A/C design tutorial...or NOT.
