911 Forum 1964-1989
'84 911 SC Turbo Fires up but Will Not Idle
Old 07-26-2010, 05:29 PM
batotal
Cruisin'
batotal's Avatar
Default '84 911 SC Turbo Fires up but Will Not Idle
Car's been sitting a long time. It's got less than 1000 miles on it.
Fires up but immediately dies almost as if it is an auto shutdown of some sort.
Fuel pump sounds normal and oil pressure indicates immediately.
Any ideas?
Old 07-26-2010, 06:34 PM
race911
race911's Avatar
The description of '84 + SC + Turbo doesn't really shed much light on what you've really got. I'm going to take a wild stab that it's an earlier-than-'84 car with a 3.0 normally aspirated engine. And from your description, a blown airbox (or massive vacuum leak) is the first thing to look for. But there's no "fix" for a blown airbox, other than replacement.
Old 07-26-2010, 07:26 PM
ricster
ricster's Avatar
Could be bad fuel as well....hard to say..also what race 911 said is correct as well
Old 07-26-2010, 07:31 PM
ron mcatee
ron mcatee's Avatar
SC's production stoppen in 1983. Carrera procduction started 1984. The only Turbo's during that time were Gray Market ones requiring DOT approval to get into the US. don't know what kinda of set-up you have. any pictures to give us an idea of what the engine looks like. How do you know it is a Turbo?
Old 07-26-2010, 08:38 PM
batotal
Cruisin'
batotal's Avatar
Well. Sorry I'm not a porsche nomenclature expert yet.
But, It's an "unmolested" '84 911 SC. That's what the registration says. It's some sort of special euro slant nose model. It most likely is a "gray" situation. It is definitely a turbo with a whale tail if that helps...It's a 3 point something or other 300 hp turbo motor.
Does this clarify?
Old 07-26-2010, 10:20 PM
Ed Hughes
Ed Hughes's Avatar
You still call it an SC, which is wrong. Those went out in '83. Is it a factory Turbo and body kit? Maybe a VIN would help here.
Old 07-26-2010, 10:31 PM
Brett San Diego
Brett San Diego's Avatar
VIN and some pics including the engine compartment...
Brett
Old 07-26-2010, 11:31 PM
theiceman
Team Owner
theiceman's Avatar
Received 1,144 Likes on 818 Posts
Does this clarify?
nope ......
Old 07-26-2010, 11:37 PM
rusnak
I haddah Google dat
rusnak's Avatar
I wonder if it's a grey mkt turbo? There are so many possibilities as to what the car is, it's not even worth figuring out the problem until it's clarified what exactly type of injection is on the motor.
Old 07-27-2010, 12:00 AM
theiceman
Team Owner
theiceman's Avatar
hence my one word response .... ..damn now I have ruined it ..
Old 07-27-2010, 12:12 AM
rusnak
I haddah Google dat
rusnak's Avatar
that's ok, your Targa retains its Sphinx-like demeanor.
Old 07-27-2010, 12:28 AM
rusnak
I haddah Google dat
rusnak's Avatar
and while we're waiting for that nugget of info....
what the hell is this emoticon doing?
we can use that one for going to dealer service. ^
I like this one:
Old 07-27-2010, 12:50 AM
batotal
Cruisin'
batotal's Avatar
I'll get some more info...
Old 07-27-2010, 05:08 PM
batotal
Cruisin'
batotal's Avatar
OK. Come to find out this Euro slantnose 911 turbo is actually a 930. viola!
In the meantime I spoke with Jack at Euromasters and got some good advice about removing the air filter and tweaking the "floater valve" to check for a stuck fueling piston.
Anyone else want to chime in and/or elaborate with words of wisdom?
Old 07-27-2010, 05:10 PM
Ed Hughes
Ed Hughes's Avatar
You should be posting this on the 930 forum.
Quick Reply: '84 911 SC Turbo Fires up but Will Not Idle
