R/S pwr mirror on 87 911
![Arrow](https://rennlist.com/forums/images/icons/icon2.gif)
L/S pwr mirror works fine, unable to get R/S to function. Manual states push down/back to enable R/S, the only thing I can get to happen in L/S mirror adjusts down. Anyway to manually adjust mirror, something I am missing?
Jerry
Jerry
There is a rocker switch underneath the left side of the tachometer and above the ignition switch to select which mirror the toggle switch on the door controls. Press the right side to control the right mirror.
Jerry,
Did Davids answer help you? If not can I ask if you have power going to the mirror that is not working. If you can hear the motor but nothing is happening you could check for a white plastic arm inside the the mirror assembly. I found mine had poped out of its socket on the back of the mirror. Just put back in with a bit of finger pressure on it was working again. I thin what happened to make it pop out was holding down the adjustment switch too long which meant the arm had bent enough to pop out of its socket.
Just an idea.
Cheers
Mark
Just an idea.
Cheers
Mark
