Optima Batteries
The amazing thing, Walmart of all places had a 911 battery in stock.
View the products spec pages to find the exact dimensions.
YellowTop
http://www.optimabatteries.com/optim...wtop/specs.php
RedTop
http://www.optimabatteries.com/optim...dtop/specs.php
Alternately, you can check the Internet enthusiast forums for your vehicle to see how others have done custom applications with OPTIMA batteries.
If you are using an OPTIMA battery in a custom application, it is important to consider the following:
1.Hood Clearance – There should be at least ¾” clearance between the top of the battery terminals and the underside of the hood.
2.Trunk/Interior Mounting – If your battery is mounted inside the passenger compartment or trunk (common in many European makes), the battery must be vented to the outside of the vehicle. OPTIMA group 27, 51, 78, 34C, and 31 batteries all have ports for connecting a vent hose.
3.Side Terminals – OPTIMA 34/78, D34/78, 75/25 and D75/25 batteries have both top and side terminals. If you are using one of these batteries in a vehicle that uses the top terminals, it is important to ensure that the side terminals can not come into contact with anything metallic (for example, the firewall or fender well), thereby causing a short. Suggest keeping the post protectors on the terminals you are not using.
When used with a properly regulated constant voltage charging system (such as an alternator) the OPTIMA will usually not emit hydrogen gas. However, gassing can occur when charging at higher voltage levels or in extreme high temperature conditions. In automotive applications this typically will not happen if the alternator/regulator stay below 15 volts
On the issue of venting - I noticed that in all the install pics that I've seen with optimas in 911s, nobody seems to bother with this. My gigantic group 91 (?) Interstate has an obvious vent hook-up (though the vent was MIA from the guy I bought my car from). Does anyone actually use a vent kit for their Optima? Does Optima sell one, or would I just use some generic plastic tubing?
I also noted in Optima's FAQ that any drilling of the case voids the warranty. Ed (and others), it looks like the cutting board mount involves drilling holes through the base of the case...has this caused any issue with warranty support for anyone?
Cheers,
Dave
An Optima spokesman has assured me that the Titanic was not using Optima batteries and Optima was in no way responsible for the ship's sinking.
I will also say that I've never had any issue with the battery. Ruby was down 9 months when I rebuild the motor. The battery was disconnected during most of the time, and a 48 hour trickle charge had her back to full strength. When I updated the motor last year, did the same for 3 months. She sat for probably a month after I got the 993, and fired right up. I'd say it is a reliable battery for a hobby car.
That is the funniest thing I've heard or seen today!
http://www.optimabatteries.com/optim...ty/postFeb.php
And they will vent if overcharged. When will they be overcharged? When you have an incorrectly set voltage regulator, when the voltage regulator does not temperature compensate and even when the latter two are met....when you have a damaged/faulty battery.
VRLA batteries cannot be opened and therefore cannot be topped up. That is their downside. They are also far more sensitive to proper charging method.
