911 Forum 1964-1989
Survived first valve adjustment
Old May 22, 2010 | 09:36 PM
GothingNC's Avatar
GothingNC
Default Survived first valve adjustment
Performed the 15k mile service today
#4,5, and 6 intake were a hair tight and #4 exhaust was a little loose
Spark plug change was a snap with the factory spark plug wrench
Other then that all went well and finished up in 2 1/2 hours, easier with backdated heat, no AC and SSI's
Runs much smoother now and the pop out the exhaust that would occur if I reved at idle and quickly released is now gone
Now it's Bitburger time
John
Old May 22, 2010 | 09:39 PM
jwilson95's Avatar
jwilson95
nice work
Old May 22, 2010 | 09:44 PM
dshepp806's Avatar
dshepp806
Yes: COOL!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I'm **** with my distributor cap and rotor. (15K min.)
Enjoy that brewsky, bro'!!!!!!!!!!!!!!!!!
Doyle
Old May 22, 2010 | 11:39 PM
User 4221's Avatar
User 4221
Great! I'm doing this tomorrow.... Including cap and rotor.
I'll post results tomorrow.
Old May 23, 2010 | 12:59 AM
Ed Hughes's Avatar
Ed Hughes
That's always a good day after doing a valve adjustment and buttoning it up.
Old May 23, 2010 | 01:07 PM
GothingNC's Avatar
GothingNC
Thanks !
I was really worried about having a seized spark plug but all were compliant during removal.
I used ramps instead of jackstands, felt more secure getting under the car.
Just finished up cleaning the road grime off the underside and will be changing the brake fluid.
John
Old May 23, 2010 | 03:21 PM
ivangene's Avatar
ivangene
Parts Specialist
way to go,
I have yet to tackle this task.... mental fear and having had it done right before I bought the car are keeping my hands outta there for now
Old May 23, 2010 | 04:15 PM
User 4221's Avatar
User 4221
I've got everything off and the engine is cooling. I'm amazed how easily this thing came apart. No pulled cover studs, no drama.
I have, however, found something interesting. I'm hoping it is SOP for Porsche but wanted to post it here (also on the Bird).
While finishing the cover removal I notice a part number on the camshaft housing. It reads 964.105.111.1R.
PET doesn't show anything on this P/N but a web search shows it as an '89 964 camshaft housing on some site called German Sports Care Spares (UK).
I know some weird things began happening in '89 on the switch to the 964.... Things like body parts, seals, etc.
However, did Porsche begin installing 964 camshaft housings on 930/911 engine cases.
BTW, I searched the engine S/N and it shows as period correct for the car and I don't see any major engine work done in the car's history.....
I'm perplexed...... Anybody else out there seen this?
Old May 23, 2010 | 04:22 PM
Ed Hughes's Avatar
Ed Hughes
There typically is no drama with removing valve covers. It is the studs hidden inside that cause the drama. Make sure the car cools overnight-it needs to be stone cold, not simply cooled off.
Old May 23, 2010 | 04:57 PM
User 4221's Avatar
User 4221
Thanks, Ed. I had planned on letting it sit overnight. It will be as cold as the Dallas weather allows
Is there any way the layman can check the head studs? I don't want to disturb them with a wrench but have pulled and attempted to turn by hand with no movement.
Anything else to try?
User 4221's Avatar
User 4221
Old May 24, 2010 | 09:17 AM
GothingNC's Avatar
GothingNC
Scott,
No need to worry about the head studs if they did not fall out with the valce covers.
Now I have to deal with my "random" hunting idle - (CIS)
I have not found any air leaks.
Purrs like a kitten and once in a while it will start revving between 700 and 950 for a few minutes and then smooth out a few miles later.
I removed the oil cap when it was hunting and the idle stablized. So I turned off the motor for a minute to check thngs out, restarted and it was running normal. I removed the oil cap again and the idle dropped like it should.
Took it for a drive and while I was stopped at a light and light a switch it started acting up again. Got back home and it was running fine
Not sure if it's something electrical or fuel related or just the normal way CIS acts.
I'm going to lean out the mixture by a hair to see what happens.
John
Old May 24, 2010 | 11:31 AM
User 4221's Avatar
User 4221
John,
It sounds like you may have the beginnings of a vacuum leak. Perhaps a hard plastic fitting is expanding/contracting with heat? Just a thought.
BTW, I solved the mystery of my 964 part number on the cam housing. It is an internal part number (casting number) that Porsche uses..... Gotta love having a transition year car.
Good luck with your idle. CIS can be tricky
Old May 24, 2010 | 11:33 AM
GothingNC's Avatar
GothingNC
Originally Posted by Scott C
John,
That's what I'm thinking.
Need to probe a little deeper...
Glad you solved the part mystery
John
Old May 24, 2010 | 03:26 PM
Brett San Diego's Avatar
Brett San Diego
I'd say it's worth having the CO set properly by a shop with a gas analyzer at this time, if you have never had it done. I don't have anything for the idle issue. Only that it's not normal.
Brett
