Survived first valve adjustment
I performed the CIS mixture "Field Test" from Jim Williams CIS primer and it passed
[I]An approximation of the correct idle mixture can be made by the folllowing:
With the engine warm and running, slightly lift the air flow sensor plate.
If the RPM immediately falls off, the mixture is probably too rich.
If you pull down, and the idle falls off, you could either be too lean, or about right. Do the step immediately below to find out.
If the RPM slightly rises, then falls off as you continue to raise the sensor plate, it may be close to right.
You are trying for about 14.7:1.
The required movement of the sensor plate is slight, on the order of maybe a 1/16" or less. [/I]
I raised the plate slightly and the revs increased just a bit before dropping.
Then I noticed the idle was on the low side, about 800, raised it to 900 and it has been fine since![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
John
John
I just adjusted my valves and went over the car from underneath. I drained the oil and filter first and then attacked the valves. I used new fasteners and new valve cover gaskets. I didn't forget to fill it up with oil. ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
I drive up on ramps and then jack the car a little higher and set it on jack stands.
![](http://i27.photobucket.com/albums/c154/95CobraR/RG73.jpg)
Just a quick update.
The hunting idle situation came back shortly afterwards.
Had the CO checked at me neighbors shop and all it needed was about
16th of a turn to lean with the allen key.
Seems to be better now and the drivers behind me can breathe better![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
Amazing how sensitive the CIS system can be if the mixture is just a little off.
John
John
Team Owner
that's why i am always dubios of the adjustments without the proper tools .. I could see that Ipanzer for example just wanted to swap parts so couldn't really help him.
I second what Brett wrote. I jerked around with my hunting idle problem for 6 six months. Gave up, took it to my local shop had the CO set and idle was fixed. Best $100 I ever spent.
Thanks to John for following through with an update.
Brett
Alfonso,
Thank you.
I used the Rhino ramps, I had plenty of room underneath and using a speed handle with swivel socket made removing and installing the valve covers a breeze.
Jacked the rear up and placed the ramps with the slope facing the front wheels then rolled it off when I was finished.
John
Thank you.
John
