What year is best for restore project
I know this is a wide open quetion, but have been toying with the idea of a late sixties early seventies 911. What are the more desierable years, and what will be more fun to drive re: weight/power if restored to original spec?
Not to familiar with the older cars, not looking to find the rarest model either. Just a good starting point.
condition trumps model yr.
the more examples you consider, the more likely you will uncover a car & deal that suits your plan.
you do have a plan, don't you?
"what will be more fun to drive re: weight/power if restored to original spec?"
hard to respond - does fun-to-drive always & only equate w/ original p:w ratio?
I'd get some hands-on experience w/ these cars (meaning long-nose models from '69-73, maybe include mid-yrs ('74-77) if you'd do a thorough rebuild / restore & NOT to original spec) before going much further. or just buy a decent driver 911T for the experience before dropping 6 figures into a '72 or '73 S project.
If you are going for original/stock restore I'd look for either a 1972 or 1973 "E" or "S"
Look for Rust - get Pete Zimmerman's Book and good hunting.
Not sure your location - but if you are in California - and you want to make a hot rod - I'd look for a nice pre 1975 so you don't have to worry about emissions and go to town.
"I'd be divorced if I did that."
win / win?
6 figures is an approximation...
donor car + parts + labor + equipt, materials & space + opp cost of the sunken "investment".
lotsa ways to cost less... or more.
one technique long favored by enthusiasts is to "do the work themselves" & not acct for their labor. sometimes this makes sense when that's time & $ you'd otherwise spend on a psychotherapist's couch or pursuing grounds for divorce.
selective memory loss can also work... for instance, just count each attempt at rebuilding / restoring / acquiring the wrong parts for a major subsystem once.
so does mis-categorizing ... apply that $8k bill from the pro shop that you eventually take it to for "final touches & tuning" to "regular maint."
then there's the "factor-in projected massive investment return" strategy. that will dig you out of a huge hole - as long as you never try to sell it.
{& btw, for me, the fun-to-drive aspect is totally devoid of numerical calculation}
win / win?
I agree with KED. Establishing a final objective helps on the front end of the process. Each year has specific qualities you should consider: short wheel base, transmission, suspension, carb/injection etc. The 72-73 cars are nice with the 915 gearbox. power/weight is a fine measing stick, but the "quality" of power is unique in the early cars as a RS spec 2.4 will scream past 7000rpm - nothing compares to the flexibility and responce of a well tuned early car. The song they sing is hypnotic.
That being said, a 72/73 is an easy(relativly) swap with a 3.0 SC/3.2 Carrera motor and the same alloy suspension components to make a sweet lightweight/responsive driver. Any option you choose can be an expensive venture and the current market on the early cars begs responsibility. Your final objective - track, investment, daily driver, RS tribute etc. will simplify things. In any case you want to find a good condition car to start with as Ked states.
I haddah Google dat
"I'm still on Wife 1.0 after 23 years. Still looking good for the long run."
that proves it - focus on high quality & pay attention to regular maintenance.
update: here's the kinda "1st old 911" I'd look into...
http://forums.pelicanparts.com/porsc...1970-911t.html
Just a thought right now don't know much about the earlier cars, so no plan as of yet. but once I commit it will be well planned out. Just looking for a starting point i.e. donor car if any years are more desirable assuming like condition.
