Stranded on side of road think it's a fuel pump
Help. I'm stuck on the side of the road. It appears to be the fuel pump. I can hear it when I turn the key on.
Where is the pump. I don't know where it is and all I have for a light is my iPhone
I was on my way to the track for a DE weekend so I have everything with me I need to fix it except a fuel pump
Team Owner
he has a Carrera so if he has already tried the DME relay , it could be the pump . but you still have to start with the basics , do you have spark etc. is head temp sensor working and connected.
I haddah Google dat
You should only hear the fuel pump when you crank the starter. If you can get to the front cross-member, the fuel pump is bolted to it. Tap on the fuel pump hard with a plastic screwdriver handle while the engine is cranking over. That might get it to turn. Kragen Auto has the correct fuel pump. I had to help out a stranded 911 owner with one.
Team Owner
I haddah Google dat
I have a mental image of Goodwin under the 911, stretching to tap on the fuel pump now. I feel so bad.
If I'm not mistaken, there is a bullet fuse that powers the fuel pump. One of the 15 amp ones I think. I should have mentioned this first.
So it could have been worse. I had it towed back to the house. I jacked it up and climbed under and got to the pump.
I put a voltmeter on the contacts and the pump started purring like a kitten. Tightened the nut and drove to the track and got the last two runs of the day.
