911 Forum 1964-1989
Starter recommendation
Old Sep 2, 2001 | 08:46 PM
Chris Martin's Avatar
Chris Martin
Post Starter recommendation
I am going to buy a new started this week and thought I might get the high torque starter from Performance. Has anyone ever used this or a similar model? I have a stock SC and dont want to add any hassle to the car with this unit, such as hurting the flywheel or having engagement probelms. Since it's only a few dollars more I figured it would be a simple upgrade.
Thanks for any input
Chris
Old Sep 2, 2001 | 09:25 PM
Bill Gregory's Avatar
Bill Gregory
Technical Specialist
Lifetime Member
Post
You may want to check the starter available through Paragon Products - $215. I've heard good comments about it. Here's the web link: http://www.smartcart.com/Paragon/cgi...m=911HTStarter
No affiliation, etc.
Old Sep 2, 2001 | 10:20 PM
Howard's Avatar
Howard
Post
I purchased the high torque starter from Performance and so far it works great. My engine is a 3.4 with 10.3:1 compression and the starter has no problem turning it over.
You'll probably have to loosen the clips which secure the wiring to the body for a little more length, the high torque starter connections are in different locations from the OEM starter. good luck!
Old Sep 2, 2001 | 11:32 PM
Dial 911's Avatar
Dial 911
Post
The OEM starter is more than adequate for a stock engine. If you need a new starter, check with local auto-electric repair outfits. They can rebuild the Bosch units for a reasonable price.
Old Sep 3, 2001 | 02:17 AM
JackOlsen's Avatar
JackOlsen
Post
When my overheated 915 cooked my starter, I passed on getting a rebuilt Bosch unit ($200), and instead got the high torque one from Pelican (for the then price of $199). The torque is a non-issue for me -- when was the last time an adequately-powered starter didn't have enough oomph to turn over the engine? But the newer unit is only 8.1 pounds, which is signifcantly lighter than the stock one.
Old Sep 4, 2001 | 10:21 AM
Chris Martin
Post
Thanks a lot for the advice. I thought about getting my unit rebuilt but due to time restraints I will bite the bullet. I like the Performance 30 month warranty, I need to see if it applies to the starter as well.
Thanks again for your input!
Chris
