Rims fit? 1981 911 SC
Location: Toronto, Canada,Planet Earth, Earth-Moon System, Solar System, Milky Way Galaxy, Local Group, Virgo Supercluster, Observable Universe
Does anyone know these rims will fit and 1981 SC. They should fit late 944's (1987 and newer), 951's, 968's, 986's (Boxter) & 996's (Carrera) not sure about the SC? Thanks
With spacers. But 964/968 wheel like that is a whole different offset animal. Torsion bar car should be 7" front with 23mm offset, and 8 or 9" rear with 11mm, right? (Going from memory.)
8" or 9" rears, 8 oem was ET10.6 but it could use a small spacer or lower ET too, 9 was never an oe fit but the 930 ET15 fit like a glove(though some have even spaced these out a few mm). I've seen 10s fitted but it is a nightmare, I use 9.5 ET19 on mine, that ET is perfect for that size and it was still a lot of work to fit them to the car.
Thanks for the comments. Fronts are 16" x 6" with 52 offset, 16" x 8" with 52 offset rears, so looks like not the ideal fit.
