My 76 911 had a bad alternator when I bought it several months ago. It tested with no voltage output. After receiving three incorrect alternators from three different parts dealer, I finally got the correct one and installed it. The new alternator, according to my local mechanics, is performing as it should and it's charging correctly at the battery but my "G" light on the dash is still ON all the time. I'm wondering why that light would be on if the alternator is working correctly??? Is there any other reason that this light would be on all the time?????
If you installed it yourself, you know there are a lot of connections to secure. Is it possible you missed one? If your "local mechanic" did it, same question.
also if it is an updated alternator you have to put a resistor in parallel with the light I think. the first thing I would do however is measure the output at the battery. see if you have at least 13v. if you don't then you are not generating the excitement voltage needed. I think your car has an external regulator does it not ? has the car been updated ?
I'm not sure what updating is for this 76 but the new alternator does have an internal regulator.as did the previous one. It is getting a good voltage to the battery....14 volts at idle and 13.5 at 2000RPM. I'm really new to these cars but I'm willing to plug along to get this one working well. All three connections on the alternator are tight and secure. Thanks for the comments so far......
okay well it has definitely been updated if it has an internal regulator .. and we Know the voltage is good from the alternator .. it has to be in the wiring .. so we need to back up a little ..
so when did the light first come on .. did you by the car with the light on ? someone needs to provide this guys with a schematic of an updated car . i wonderif the wiring was done correctly when it was updated ....
I just posted a link to the update rocedure a little while back .. I think there is a wire off somewhere, or in the wrong spot.
The light was on when I bought it. I replaced the alternator and made the connections as on the original one. The large ground wire was connected to the bolt on the left side of the fan housing and to the engine....That's the way it is now. Is there a change that needs to be made to the dash "G" light???
If you know how to test for voltage drop, check the cable going to the starter from the alternator at the starter end. Might want to have the alternator tested also. You have to take it to an alternator shop that will spin it and test it, not static test it.
Well he is getting 14 volts so the alternaor is definitely putting out ... Do a search here or on pelican for the alternator update. there is a artcicle stating whayt needs to be done. i think ther is a wire that goed from the alternator right to your light... I wil look over my bentley but i have an external regulator.
I could be wrong, but the diodes could be burned up. It's been a long time since I had my factory manual (can't find the set for some reason), but I think if you disconnect the battery with the engine running, the diodes can be damaged. But don't quote me on that.
Could also be a faulty regulator. I think it's time to get out the multimeter and actually go through it methodically. Use the volt setting, not ohm setting when testing voltage drop.
The Alternator is a rebuilt one right off the shelf from Gernam Auto Dismantlers. The regulator should be good and again it's putting out and doing it's job at the battery. I can't figure that if the alternator is rebuilt, getting good voltage to the battery, the battery is fully charged,.....but....the light is still on.....
