Bad or Not Bad?
#32
Parts Specialist
Parts Specialist
911-606-230-00-M85 Oil Pressure Warning Switch, 911/911 Turbo (1974-89), Each
and
999-707-314-40-M213 Internal Thermostat O-Ring, 911/911 Turbo (1974-89)
TIA
#34
Anyone ever have any issues with jackstand slippage. When you jack up one side and place the stand, it seems possible to have the stand slip/slide as you jack the 2nd side as the car is kind of pivoting on the stand. No?
#36
I haddah Google dat
I use two jacks if I'm lifting the front, in order to avoid putting torsion on the body.
In the back, I usually lift from the crankcase, and place the jacks under the torsion tube - both at the same time so I don't have the side-to-side problem. I've seen some awful pictures of 911s that fell when the jackstands tipped over using the side-to-side method.
#37
At the rear, I use a 2 x 4 piece of wood that contacts both exhaust headers (SSI type) plus a piece of 1" pine under the crankcase, just forward of the oil drain. It's supported at three places that way. Jackstands under the torsion bar ends or the frame where it bends upwards toward the rear. At the front, I place the jack about 15" behind the air dam, where there's a raised section running across the car. Jackstands under the control arm attachment points. Whenever possible, I use the side jacking points - like when changing brake pads.
#38
Does anyone have a link to the oil pressure switch DIY? I was planning on doing my "4" oil return tubes and "while I am there" is the oil pressure switch something recommended? Any thing else?
I use 4 jack stands and put the wheels under the sides of the car in the event it fell off the stands the wheel would catch it.
#39
#40
Thanks Peter. I thought the oil return tubes looked pretty straight forward. Guess there is a bit more to it. I have read they pretty much get destroyed coming out and can be a pain.
#41
If you look at the pictures I posted above, you can see that old tube had to be cut to remove it. I crushed it with a pair of Channelocks, then cut it with tin snips. Talk about commitment! I did mine without removing the exhaust, because I'm stubborn, or stupid. The hose clamps on the new one are critical to give you something to push against to expand the tubes. You'll remove them afterwards. Have fun!
#42
I was wondering why you had the hose clamps as the ones for sale do not have those. I guess you tighten them around the tube and then can push on them to get the tube securely in and then remove them?
I installed my cat bypass and GHL exhaust, so I am familiar with it under there, but was hoping to not have to drop the exhaust.
#43
You got it. Make sure you feel the rubber collar on the tube "seat" distinctly when you push. A tiny bit of oil on the rubber will help. Orient the hose clamps so you can still get a screwdriver on them to remove them after the tube is installed.
#44
Team Owner
if your doing the oil pressure switch and o ring you may as well do the breather cover gasket. that is often what leaks back there. or should I say " up there"
taking the exhaust off can be risky in the area where the exhaust fastens to the head . if your not experienced with that take care. Bust a stud and you will wish youhad never started the project. Work around the exhaust if you can . A real PITA but a lot less risk.
