Metal click on dash
Metal click on dash
My first post here and I hope someone can help me out. I recently just replaced my starter motor with a rebuilt mini-starter. The mechanic had to rewire it to reach. So now after installing, the car would only start on the third turn of the key. But the most annoying problem is the CONSTANTmetal clicking sound every 6 secs. coming from the dash by the middle vent. When I open my driver door it stops and my power window doesn't work anymore. The open door buzzer stopped as well. The battery seems fine. Any suggestions?
Suggestion? I'd go back to the "mechanic" who allegedly had to "rewire" to hook up a new starter. I've get to see a starter that will bolt to a 911 and not allow the stock wiring to work. I've got the smaller High-torque starter and it hooks right up to the standard wires.
It sounds like some connection is suspect. Again, I'd go back to the installer.
The mechanic has been working on 911's for 30 years. I sometimes question myself on why these things are happening to me. I actually took the care for the service elsewhere but it was too far away. Both mechanics know a lot of things but there are new things to discover as well.
electricity is magic. strange electrical (& even non-electrical) things can happen behind / under the dash when mods (electrical or not) are performed behind / under the dash. it isn't always (ever?) a clear & direct association. all you believe is that there is a temporal correlation between the starter being replaced + the ignition wiring modified & your new problem. so, rather than us speculate on the myriad of possibilities, why not go back (w/ the car) to your highly qualified, 30yr pro 911 mechanic & have him check it out?
if you hang out there while he analyzes it, he may reveal that he screwed something up (no charge!) &/or you might learn something new & interesting. on old 911s, it is not unknown for failures take place when something nearby or functionally associated has been fiddled with... like a voltage spike or short at the ignition switch caused by a tool making contact to metal somewhere nearby.
curious about the start procedure - please tell us more, "only start on the third turn of the key" - I'm not clear what that means - it takes 3 attempts to get the starter to engage, or the start function takes place at a different ignition key position now? in either case... not kosher. good luck!
It takes a third attempt to start. Honestly I thought I was stranded again. But it will start only after I hold it a little longer. Its an '89 model and I would think by then everything would be sorted after 24 years. But anyone looking at the placement of starter motor, wires and fuses, this car makes no sense. Its sloppy design.
If your car has been modified, all bets are off.
Sounds like you may have an issue with your starter; solenoid or something.
911 are a little unorthodox by design. They require experience and it sounds like you may have a qualified tech, but be patient. I know you are frustrated and thats understandable. It sounds like you may have a "multi-headed dragon" - more than one problem. Furthermore, the starter failure; Is that the problem or a result of a problem. Is it the chicken or the egg? You can clean up eggs all day long but you won't solve the problem until you solve the chicken. I would most certainly take the car back to your tech and give him a shot at further diagnosing the problem.
What kind of work has been done to this car? After-market alarm/stereo? Any engine/suspension mods? and when did you first start noticing the problem?
The engine was rebuilt @250K miles and it has 301100 right now. Daily driver that drives nice.The car is pretty stock except for the rebuilt mini-starter. I probably will take it back but I spent quite a few bucks already......
I haddah Google dat
The starter will not turn over unless the little gear on the solenoid is kicked out all the way first. It could be sticking. Try cutting the old wire off, and installing a thicker, or "primary" wire and a higher quality connector. You can get some nice ones at Orchard Supply Hardware, and primary wire can be bought anywhere. It could be that you need more power to the starter. Either that, or return the starter for another one.
The ticking could be the alarm module. To find out, you have to remove the trunk cover and look around for the source of the ticking. Put your hand on the components to try to feel for the clicking. The components are identified in the Bentley Publishers service manual.
