Battery, alternator or neither?
If I dont start my car for a week or so it dont start. No crank at all, nothing!
If I jump it, it fires right up. If I start it every other day or so it is fine.
Battery is an interstate, 3 yrs old.
BTW, how do I remove the battery?
88 3.2
thanks, leo
88 3.2
thanks, leo
Could be battery, could be bad connections, could be a drain. Removing the battery is simple- there is a clamp at the base on the leading edge most likely, which holds down that side. The back side slides under a lip.
I haddah Google dat
I would definitely want to check the water level, charge the battery, knock the static charge off by cranking the starter a few times, then check the voltage. If the battery is ok, then clean the connections, and put some dielectric grease on the battery posts.
A discharging battery will let off fumes that will leave corrosive salts on the battery connections. The positive battery clamp is notorious for going bad on the 3.2, and eventually will have to be cut off and replaced. I installed a heavier and longer negative battery cable on mine.
Who's to say what kind of bolt is there? Over 20+ years, anything may've found its way into the hole.
I haddah Google dat
The factory tool kit has an allen wrench with a rubber cup to extract the allen bolt. But I agree, as long as the thread is the right size and pitch..then..??
After the battery is charged, and the car is running, you can check the alternator output with a voltmeter to be sure that your charging system is working ok.
There is no tool of any significance. If it is an Allen, use an Allen socket on an extension. If it is a hex, use a socket on an extension. This really shouldn't be an issue-it is absolutely straight forward. I don't understand what you question here? It really is simple.
Be careful unbolting the positive clamp-dont' hit the wrench on any surrounding metal. Unhook the negative first.
Going on memory and posting here takes more time than simply being in front of it and doing. Really.
I haddah Google dat
Leo, try disconnecting the negative cable, and charging the battery with a good charger. Do not overcharge the battery, and if it's really low, try using a trickle charger or a 2-amp setting on your charger to avoid boiling the water out.
You might not even need to remove the battery yet. Check the water level. Do not just jump it, then try to drive off. Driving it will not completely charge the battery, and you can overload your alternator by driving with a low battery. Once the battery is fully charge, and the clamps are cleaned, then you can proceed to test the battery, alternator, regulator, etc.
I haddah Google dat
You have to turn the multi-meter to DC amps and set it to measure in the .000 or thousands of an amp. Bentley says up to 100 ma, but we've found on this board that the 3.2 911 draws less than 50 milliamps, and the battery lasts easily for up to two weeks.
