911 Forum 1964-1989
87 Carrera ODO ooops. info needed.
Old 02-05-2010 | 01:38 AM
superpilot27's Avatar
superpilot27
Default 87 Carrera ODO ooops. info needed.
My 1987 Odometer gave up last night. Oops. Speedo works fine. This car is my daily driver and I love it. but I need the odo.
I read the posts in this forum and it sounds like it could be:
a sending unit under plate behind seats or
broken gear and needs to go off to be fixed.
spedometer.com in Austin, TX sounded like the place to send it if that is what needs to happen.
Do you guys have any advice about testing the unit so I can confirm which route to go
1. replace sending unit
2. repair Odo/Speedo
thanks
Old 02-05-2010 | 01:43 AM
Amber Gramps's Avatar
Amber Gramps
North Hollywood Speedo
http://www.nhspeedometer.com/
Old 02-05-2010 | 08:42 AM
ned903's Avatar
ned903
When this happened to me a couple of years ago I used speedometer.com. They were very helpful, but I am basically local. North Holltwood seems to be the gold standard. Is there a great difference in price?
I’m no expert, but it seems to me that if only the odo has failed, it is the drive gear in the gauge. Is the speedometer still working?
Also, several people have replaced the gear on a do it yourself basis.
Old 02-06-2010 | 06:35 PM
pingman's Avatar
pingman
I second Mr. Bray's reccomendation on North Hollywood Speedometer. The sending unit would also affect the speed output. Mine failed a while back on an '87. NHS had a quick turn-around, cleaned up the dial and lens and answered all questions. Real good folks to do business with. Mark
Old 02-07-2010 | 10:09 AM
whalebird's Avatar
whalebird
I have had 100% satisfaction with North Hollywood. They have done such good work for me.
Old 02-09-2010 | 03:23 PM
Jay H's Avatar
Jay H
I agree with others that its the odo gears that are broke. Common issue. I sent my speedo to a vender in TX to save a few bucks. After I got it back, it then had to be sent to North Hollywood Speedo to be fixed completely. So, I didn't save any money with the TX vendor.
Old 02-09-2010 | 03:25 PM
M491's Avatar
M491
yep, if the speedometer is working, you can be 100% sure it is not a sending unit issue, but is the gears internal in the speedo.
Old 02-09-2010 | 03:27 PM
M491's Avatar
M491
It's actually not very difficult to fix it yourself, if you are handy. Usually what it is is the gear that drives the odo is slipping on the shaft. It's not that hard to carefully remove the bezel and glass, pull the "guts" out, and use a drop of superglue on the gear and shaft.
Old 02-09-2010 | 03:28 PM
M491's Avatar
M491
I think there are some DIY instructions on the internet, or the bird board, try a search if you are interested.
Old 02-09-2010 | 04:09 PM
g-50cab's Avatar
g-50cab
North Hollywood Speedo -
Old 02-09-2010 | 04:33 PM
theporscheguy's Avatar
theporscheguy
When working on a odometer are you required to be a certified facility? When I had my gear replaced due to the same issue years ago that was a standard requirement, although this may be a state requirement rather than federal.
2001 996 Carrera-Sold
1995 993 Carrera-Sold
1987 928S4-Sold
1987 944-Sold
1983 944-Sold
Old 02-09-2010 | 04:58 PM
rusnak's Avatar
rusnak
I haddah Google dat
I thought the replacement gears were available aftermarket, maybe through Performance Products?
Old 02-09-2010 | 07:02 PM
theiceman's Avatar
theiceman
Team Owner
don't be a wus .. try it your self .... then if you fail .. just send it to North hollywood in bits ... I say go for it ..
Old 02-09-2010 | 09:32 PM
Ed Hughes's Avatar
Ed Hughes
A good time for the reminder: DO NOT reset your odometer while underway. This seems to be the cause of many a failure. Do it while you're sitting at the gas pump.
Old 02-09-2010 | 10:28 PM
bart1's Avatar
bart1
DIY. Here's the place to get it:
edit: Jeff at http://www.odometergears.com/porsche.html is the place I meant. No affiliation with either, but Jeff is a good one.
Quick Reply: 87 Carrera ODO ooops. info needed.
