Windows fog up, but it ain't cold outside
does anyone else share this experience - the inside of all my windows very quickly accumulate a very thin layer of haze, unrelated to the weather. On average, I've needed to clear the interior side of the windows easily twice a week (to compare, I need to clean the inside of my wife's BMW about once a month).
All the climate control switches on my 79SC are fully to the left-hand side (off position) and the heat levers down next to the emergency brake are in the full down position.
The only thing I can think of is that I do get a small amount oil burn from drips hitting the exhaust system, but for the most part, the windows are always closed after shutting down.
This one's a puzzler for this new owner.
Joe
Joe
You have the "Porsche Fog", and you are not alone.
Sources may include:
- wet rugs (front windsheild leaking? check above glovebox -or- side window scrapers)
- oil fumes in the in a/c, fresh air or heater vents
- odd fumes that slowly appear out of the rugs, leather, glues and plastics in the car, yes even after all these years.
Nearly every P-car that I had hazed up on me. There is no real cheap-easy-fix other than leaving the windows/roof open when the car is in the garage or on hot/sunny days. I keep a small shammy-cloth in the door compartment for a quick and streak-free wipe-down
