rpm at 70 miles
6th Gear
Hi,
What is the rpm at 70 miles/hour for your 911 3.2? Is there a different differential setup for different cars produced in the same year?
thanks..
thanks..
No, to answer your question. All the Porsche owners manuals have a rpm/mph chart toward the rear in the "specifications" section. You will get your info there.
Keep in mind as we've moved on in the world of tires from the 80's, that diameters are somewhat all over the map, even for the same sized tires from different manufacturers. This will effect the final answer.
Kagan, I just did a test of my car with Yokohama ES100, 16" tires on it. At 70 mph, my speedo reads 3100 rpm. As Ed stated, tires may have an impact on readings since a lot of them have different rolling radius's.
I haddah Google dat
My SC was geared much lower, so add 1K rpm to the 3.2 rpm figure.
6th Gear
hmm I see.. I recently bought a 84 targa and I am still trying to get used to the car and trying to learn the characteristics
. I know that the tire specs will affect the speed and rpm on the first hand. These are very close to what I have despite the wheel size (my 84 targa has 18 inch wheels). Thanks so much..
