I'm Having Turn Signal Issues
First they stopped making the clicking noise and now they only work intermittently...about half the time.
Any suggestions? Thanks in advance.
That's what I suspect. It's all or nothing: either they work fine or they don't work at all.
It seems to alternate: good, bad, good, bad.
Thought I'd update.
I changed the fuses and flasher relay, but no improvement.
The turn signals and emergency flasher now work about 10-20 percent of the time. Either both turn signals work fine, or they don't work at all. In addition, the emergency flasher doesn't flash if the ignition is turned off.
Bad turn signal switch? But would that also affect the emergency flasher? Maybe just a loose connection?
I hate electrical issues. Any ideas welcome. Thanks...
