Radio/Deck Wiring in 1970T
Hello-
I'm in the process of installing a radio/cd in the gapping hole in my dash where the previous owner removed whatever was in there. Short story long,
I've been advised to go directly to the + on the battery and then look for an accessory lead. However, I'm trying to sort out just what's going on under the dash as long as I'm contorted. I'd appreciate a quick overview/guide on what available wires (colors) I might use per my deck mfg. guide which states the following wires from the deck harness to be connected as follows:
Memory backup lead: connect to battery with 15amp fuse
Bus power lead: connect to battery with 3 amp fuse
Power lead: connect to accessory
Ground: vehicle chassis
Illumination lead: car power supply terminal
Auto Antenna lead: power supply terminal for antenna
Many thanks in advance!
