Alternator Fan Housing ...
#31
Well, I'm still at it guys! I took some pics which I will post but even with some of the "fixes" I did, I still had to still tweek it when mounting mine back up. If you get a Vertex part and want to do the adjustments yourself, just get ready for some work. If you like me with a short fuse, then I guess it will be an adventure. Anyway, I hope to be done at some point this evening and hopefully I will post the done job.
#33
Ed I agree with you on that! However, there are some minor adjustments but I had to do a lot of adjustments. I think the part is not that bad, but I don't think after they have it built they fine tune it to make it fit at least closer. Well the good news is that I'm done and I took it out for a ride and it is nice. The lights are more brighter than before so the 90amps are doing their job. I will be posing the pics soon so you all can see. Thanks!
#35
Well guys as promised, here are some pics of my little adventure with the Vertex housing. I did not took any "before" pics since at the time I was trying to fix my original housing. However, after the machine shop told me that my housing was not able to take the welding I started to look for a replacement. Anyway, the summary is that I had to adjust the Vertex housing because it came in bigger on some areas on the outside and in the alternator area was too tight. After adjustments were made I then mounted it and all is back to normal. In the first pic is the housing, rough casting. The second shows some of my adjustments by sanding the top area. The third pic shows where the notch on the block is supposed to go. I had to move it in order to get things lined up correctly. I then painted the housing and the original fan and after adjusting where the alternator goes in, the back of the alternator went all the way like it is supposed to go. Then the last pics shows the housing mounted and my car.
#36
I haddah Google dat
I would be SOOO tempted to sand off "Vertex" in that second pic, which looks like the casting is a bit rough.
Nice job though! Nice looking paint!
#37
Job well done! Paint job looks great.
Where are these made? Is that South Africa? They seem to have a "Huge" timing mark where the original only had a line.
#38
Thanks Rusnak! Yeah the casting is rough and although the part is painted with a type of grey or silver grey, you still see and feel it. I guess they don't fine tune the part after casting which I believe made the issues with adjustment. I guess it may not be the same for everyone, but I doubt that they come perfect at all. Kiwi here had to have his mechanic make adjustments to his before it was installed. So, I'm guessing he went through the same thing I did!
#39
Thanks Psycho! I wish I could have powder coated, but I was more interested in getting the car back to running. So a good old fashion hand spray painting did the trick. As to the housing I think they are made in South America, not sure. Yeah the timing mark is not position all of that correctly and it is too big.
#41
Thanks for reminding me, I thought about doing it when I finished but forgot! I was so tunneled vision about getting everything done and testing it, and forgot all about that! Thanks!
#44
Just another data point on the Vertex housing. I bought one to replace my cracked original. I really didn't have to do much in the way of fitment. I found that the machined opening where the alternator slips in was a bit too tight for my liking (the fit of the alt in factory housing is also quite tight in my experience). I simply used my dremel with a small sanding drum attachment to get a little more clearance (or rather a little less interference). Spent maybe 15min on this, otherwise it was a bolt in for me.
#45
lpsalasaman ... nice install ... sorry for the slow response I have been on vacation without access to the internet ... a true vacation.
just my $0.02 ... I found I only had to do some minor filing, more like finish work for the casting. I was able to use an SC for reference on the fitment. I spent most of effort on aligning the alternator, making sure it did not bind, spun freely and the blades on the fan did not make contact with the new housing.
I put over 1500 miles on the car before I sold it . I made sure the new owner was aware of everything I had worked on. He is a tinkerer (sp?) and has owned 911 before. He drops me a line every now and then to let me know where he has driven or what he has worked on.
Last comment ... I found the Conti belts "stiffer" than the OE Porsche belts. The OE belts fit better around small radius the pulley. I used the Conti belts for backup. I am not sure it makes much difference just an observation.
Once again thanks to the this forum ... guys like Iceman, ED and Rusnak have been big help with suggestions and information.
