911 Forum 1964-1989
Electrical gurus, I need help figuring out why my wipers (front & rear) do not work!
Old 10-04-2009, 12:58 PM
gerlando
gerlando's Avatar
Default Electrical gurus, I need help figuring out why my wipers (front & rear) do not work!
I posted this over at PP and didn't get very much in the way of replies. I'm hoping someone here can help...
It's getting close to the rainy season in Washington state so I cannot put off fixing my wipers for very long. My rear wiper has never worked for me and my front wipers recently stopped. They failed progressively though, the stalk controls stopped working first and a few weeks later the intermittent switch stopped working.
I'm "ok" with electrics and I have a Bentley manual and multimeter, but the wiring of the 911 has me confused. How can I test both the front and rear wiper systems to determine the point of failure?
Also, I took apart the rear wiper motor yesterday. The original gear oil had the consistency of gummy candy. I re-oiled it, put it back together and double checked my Bentley manual to find that the motor had been wired incorrectly! Once I put the wires back on it motor ran for a bit, then got stuck. I moved the magnetic spindle a bit and it worked for another minute or so before dying again. It appears to not be able to overcome the resistance of the plastic "ramp" on the main internal gear that causes the switch to flip. It seems like the motor's fried. :-\
Old 10-04-2009, 01:06 PM
Amber Gramps
Amber Gramps's Avatar
I'd say getting power is 90% of the battle. After that, it's mechanical issues and it sounds like you have that under control too. I'd manually work the wiper motor. Try giving it 12 volts off the car. (Bench test it is what I'm looking for...) If replacement is the only option then that's just one more new part your car has collected.
Ground wires can always be an issue....
http://www.pelicanparts.com/cgi-bin/...ILTER_TOOL=ON#
http://www.autopartswarehouse.com/se...+motor&submit=
same part $70 off
Old 10-04-2009, 01:07 PM
gerlando
gerlando's Avatar
I should have specified, I've pretty much given up on the rear motor & removed it from my car. The front wipers are my main concern.
Old 10-04-2009, 02:34 PM
theiceman
Team Owner
theiceman's Avatar
Received 1,101 Likes on 786 Posts
as doug points out the first step is get your meter in the connector and see if you have 12volts .... it all starts there .. if you do you need motors... if you don't ..post back ..
Old 10-07-2009, 04:51 PM
originalmotorhead
originalmotorhead's Avatar
What would cause the wipers to not return to their 'rest' position? That's what i am dealing with. My various speeds work but when you click the stalk to the off position, the wipers immediately stop regardless of the position on the windshield.
Tom
Old 10-07-2009, 05:13 PM
rusnak
I haddah Google dat
rusnak's Avatar
There is a one-way diode that needs to be wired correctly. See wiring diagram.
Old 10-07-2009, 05:16 PM
theiceman
Team Owner
theiceman's Avatar
as oppose to a two way diode ?
Old 10-07-2009, 09:23 PM
ron mcatee
ron mcatee's Avatar
My rear wiper had the same problem as yours. I found the fuse was bad on the 3 relay mount in the left side of the engine compartment.
Old 10-08-2009, 01:18 AM
rusnak
I haddah Google dat
rusnak's Avatar
Doh!!! haha, you got me. I suppose I was trying to say that you have to wire it directionally.
Old 10-09-2009, 01:05 PM
gerlando
gerlando's Avatar
Doh! I checked the 3 fuse in the trunk instead of the engine compartment. It didn't make sense at the time, obviously because I wasn't paying close enough attention to the manual!
Old 10-09-2009, 02:57 PM
ron mcatee
ron mcatee's Avatar
Gerlando, that fuse block needs to be removed and checked to ensure it has not shorted out. It is hard to explain, but I'll try. On the back of it it there are three copper flat pieces. They conduct current to the fuses. However two of them are connected to together (made that way) which provides continuity for a third fuse....I don't recall which. On my fuse block, it had burned through (shorted out) and there was no longer any continuity. I soldered the two pieces together where they had burned in two and voila, it worked. I tried ordering a new fuse block for the engine compartment, but they are no longer availabel (NLA). that's why I went the soldering route.
Old 10-09-2009, 04:54 PM
originalmotorhead
I'll check my bently book tonight. where is the diode typically located? in the column or under the hood?
Tom
Old 10-09-2009, 08:04 PM
gerlando
gerlando's Avatar
Ron, I checked the rear fuse and the red wire appears to be getting full power so I think the box isn't the problem. On the other hand, on the red/black wire I'm only seeing 2v regardless of the switch position.
rusnak, I believe I saw the diode right next to the switch. It's rectangular clear plastic and wired inline with the switch. Are these replaceable? I couldn't find on in the catalog here.
Old 10-09-2009, 08:55 PM
rusnak
I haddah Google dat
rusnak's Avatar
I'm sorry, but are we talking about the rear or front wipers? I'll grab my Bentley as well and take a look.
Old 10-09-2009, 09:43 PM
theiceman
Team Owner
theiceman's Avatar
I haven't been totaly following this hread but if he is getting power I think it is in the motor. If I remember correctly the device that ensure full return before stopping is in the motor also .
Quick Reply: Electrical gurus, I need help figuring out why my wipers (front & rear) do not work!
