Distributor Rotor question
Should there be electrical continuaity with the rotor out of the distributor from the center of the rotor to the outer edge conductor on the rotor? Does it form a conection when the rotor spins? Is there ever any connection between the two? Any input on how a rotor works is appreciated. Thanks.
Hi David,
Check out this site for more info on ignition system...it's got cool graphics . Coincidently, I just changed caps and rotors on my C2 yesterday...
got rid of a slight miss that I had...now she goes VROOM-VROOM!
<a href="http://www.howstuffworks.com/ignition-system.htm" target="_blank">ignition system</a>
