1987 Porsche Smog Check and DE
I am looking at 1987 with 150k miles. The top end was rebuilt 20k miles ago so is the clutch. The owner has a catalytic converter by pass. Car is in Florida. I am in CA
1. If I put the catalytic converter back on, what is the chance the car would pass CA smog check?
2. The car had 6 DE events after the top end rebuilt. Compression is 150,140,140,145,145,150? Leak down was not done. Is this still ok?
Thanks.
Thanks.
I haddah Google dat
It should pass, but don't they have smog testing in Fla? Can you get a test of the CO%? You may need to re-connect the green wire next to the DME under the driver's seat.
