911 Forum 1964-1989
E-bay RSR WOW!!
Old 08-06-2009, 06:51 PM
Peter Zimmermann
Peter Zimmermann's Avatar
And a hydraulic clutch linkage...
Old 08-07-2009, 11:39 AM
butzip
butzip's Avatar
LOL!! I didn't catch that one...... that actuates the muffler valve right??
Old 08-07-2009, 12:01 PM
Peter Zimmermann
Bidding done - reserve not met.
Old 08-08-2009, 01:42 AM
Tango635
Tango635's Avatar
For all you Gurus...How much is a car like this worth? It has some details that need to be worked out, but it's not a bad place to start, right? The only serious sin might be the JE pistons. What's the problem with JE pistons, are they that bad that the right thing to do would be to pull them out and replace them with what?
Old 08-08-2009, 10:38 AM
theiceman
Team Owner
theiceman's Avatar
Received 1,127 Likes on 807 Posts
Originally Posted by Ed Hughes
Seems like a race car could use a shift light or oil pressure light in place of the clock?
Overall, it does look pretty fun.
"well it turned out my engine died due to no oil pressure .. I had no idea of that but i can tell you it happened at exactly 12:15.... according to my clock .."
Old 08-08-2009, 11:43 AM
whalebird
whalebird's Avatar
Tango635... It is hard to evaluate a car like this. Often a well constructed and proven track car can be worth a lot more than the original car. This is true for Turbos and the early 911 varients. However, value is hard to assign to a car that has no history, no log book, and a relativly small number of comparative vehicles to evaluate against.
In summery, a proven track car is worth a lot of money but it takes a lot of money to make one. JE pistons and cylinders have tried to nudge into the aircooled porsche market with cost effective alternatives to the expensive Mahle P/C . Mahle has been the cornerstone of any quality aircooled engine project. I have personally been involved with 911SC projects who's engine was pushing the $30k and still using factory CSI injection. JE pistons are not acceptable alernatives in a top quality aircooled Porsche project.
Old 08-08-2009, 12:01 PM
Ed Hughes
Ed Hughes's Avatar
Does that mean the oil pressure will be correct at least twice a day?
Old 08-09-2009, 04:50 AM
Tango635
Tango635's Avatar
Thanks Whalebird. I appreciate the education.
Old 08-09-2009, 08:33 AM
early_grayce
early_grayce's Avatar
Lots more pictures of the car here:
http://www.race-cars.com/carsales/po...47160256ss.htm
Old 08-10-2009, 08:04 PM
fat cab
fat cab's Avatar
WOW $97,000
Old 08-10-2009, 08:33 PM
Peter Zimmermann
Still no pictures of the suspension, brakes, front apron, or hydraulic clutch set up. I wonder what kind of timing chain tensioning system is used (no Carrera tensioners)? I wonder what "calculated" hp & torque is?
Old 08-10-2009, 08:43 PM
g-50cab
g-50cab's Avatar
that always blows me away about a car like this - do all the work then guess on the Hp - what's a dyno run? Mine was $85 a session and I know exactly the HP - And more importantly the A/F ratios
Quick Reply: E-bay RSR WOW!!
